Room Tag with leader, why the space between leader and room num box?
3 REPLIES 3
Jason_S
1349 Views, 3 Replies
Is there a way to close the space between the Room Tag leader and the room number box? See the attached png file.
This gap seems to get larger if the room name is larger.
Thanks for the help
Revit 2009 and 2010 Architecture.
3 REPLIES 3
in reply to: Jason_S
I too am searching for this answer, seems weird that the space is even there. Any help would be great!
dougrelf9665
I have the same problem. I wish someone who knows would let me know. Thank you!
L.Maas
This is the way Revit solves it. Basically it draws the line to the edge of your tag. In your case the T from Toilet becomes defined as edge of your tag. You are correct in your observation that when the text gets longer than the gap gets bigger. A real solution is not available. You have to resolve to tricks to get around this. Solutions that I have sometimes used are making sure that text is smaller than the box. Add lines in your family that "seem" to connect to the leader (with visibility parameters for left and right) and so on. Maybe not neat but might be the solution to your problem.
Louis
Please mention Revit version, especially when uploading Revit files.
