Room Tag Issues
4 REPLIES 4
chris_pitt
2087 Views, 4 Replies
Room Tag Issues
Hi
I'm having issues with positioning room tags.
When I try to position my prefered tag in some, mostly, small rooms I get an out of room error.
I assume this relates to an insertion point over which I have no apparent control which can be clearly seen, a green line, when trying to move the tag - see attached screen grab.
As I don't want to use a leader any suggestions or am I missing something obvious?
Regards
Christopher Alan Pitt
Frank Shaw Associates
4 REPLIES 4
CoreyDaun
in reply to: chris_pitt
It appears that the Elements in the Family are not located on the origin point (intersection of the reference planes). You can open the Family for editing to correct this, but all of your existing Tags will be changed as well.
chris_pitt
in reply to: CoreyDaun
Noted but the family editor doesn't give me the option for reference planes, only reference lines
Regards
CoreyDaun
The Reference Planes are already there. Most likely, Annotation Categories are turned off under Visibility/Graphics Overrides.
chris_pitt
Thank you!
Rail Community
