style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
<rtalbott> wrote in messageMy
href="news:6097813@discussion.autodesk.com">news:6097813@discussion.autodesk.com...
goodness! How quaintly inefficient. I must be spoiled by ALLPLAN.
Nevertheless, thanks very much for the info. I have no doubt I can get used to
doing, then modifying. Richard
"rtalbott" wrote in messageIn
href="news:6097893@discussion.autodesk.com">news:6097893@discussion.autodesk.com...
further testing using various templates, I have found that it is normal for
the temporary dimension tolerance setting to be 6". How I got stuck with
x/256" on an earlier experimental project, I don't know. A 6" tolerance is
much less frustrating, but I would still like to know where the tolerance is
specified. Any ideas? Richard
href="news:6098012@discussion.autodesk.com">news:6098012@discussion.autodesk.com...
think you solved it. I found the SNAPS settings in the SETTINGS menu, not in
TOOLS. Without knowing the design strategy of the length dimension increments
field, which you described clearly, I couldn't prove to myself that that was
what I was looking for. Thanks very much Richard
Hello.
I would like to have more inform regarding this post. I have been frustrated with the temporary dimension displaying to the nearest 1/256". My preference is if I can see temporary dimension to the nearest 1/16" and how do I do this?
I tried changing the snap distance as mention here but have had no luck. Will someone please guide me a little more on what to do. It will be greatly appreciated.
Thanks in advance.
EJ
