Please see attached rvt file. I have created two roofs by footprint and slope arrows using the same roof type and they abut on one edge as shown. My issue is that although the base of the roofs are both set at 4.000m, the top surface of the roofs are not even. This then has implications for adding fascias and gutters that won't join. I understand that this arises due to the different roof angles in my file, but I am wondering if there is a solution that will allow me to easily align the top surfaces of the roofs?
- Mick
Solved by constantin.stroescu. Go to Solution.
I suggest using a flat Roof by Footprint on which to apply Modify Sub Elements:
Image 01
Image 02
Image 03
Why two roofs? What´s wrong with making this as one roof with two different slopes?
Alfredo, I had considered that which works on that simple test file, but the actual roof I'm doing is quite an elaborate structure and with some experiemention I found that calculating and setting angles didn't work for me exactly. Thanks for your reply.
Constanin - I think that's what I'm after - I'll have to see if it works on my full model, but that definitely is a step in the right direction. Thankyou for your detailed explanation.
Regards
- Mick
No problem. Just be aware that the method of modified subelements can cause an irregular thickness in the roof or slab.
Thanks Alfredo, yes I noticed that - it would be good if when using slope arrows that revit gave the option to either:
a) vary the roof thickness so that the roof top and bottom align; or
b) adjust the roof top so that the top edges always align; or
c) adjust the roof bottom so that the bottom edges always align (which is what it does now).
Regards
- Mick
