Roof Shingle Extend
2 REPLIES 2
mgagnonbl
2457 Views, 2 Replies
Roof Shingle Extend
I'm fairly new at this and am trying to learn some features in my spare time. I am looking at a section cut through a house i'm working on and am zoomed into the roof edge which is the basic roof (wood rafter 8" - asphalt shingle - insulated. I'm trying to figure out how to extend the asphalt material over my fascia board. I go into edit mode and it wants me to pick a view to edit from. I wont be able to see this in roof plan view. I've tried finding a solution online but no luck. It seems like it should be easy enough. Thanks for any help.
2 REPLIES 2
loboarch
in reply to: mgagnonbl
You can do this by altering the cut profile of the roof edge.  http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-BE871A38-C99F-4D07-93B5-576CEBA0E68D
This will not change the model geometry but it will be correct in the section/detail view you are showing it.
If you wan tthe model to show this condition, you would needt o model the shingles as a seperate roof with a slightly larger over hang than the roof below.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
mgagnonbl
in reply to: loboarch
I like the second idea for now only because I'm trying to get experience modeling something. The sectional detail can be altered any time I believe? So for now there is no way to edit that assembly and tell it to say overhang the sheathing by say 1 1/2" or so? I'm going to give the shingle modeling a try. This is awesome. Thanks for your suggestions.
