Roof Overhang
1 REPLY 1
YehudaInbar7952
376 Views, 1 Reply
Roof Overhang
When I specify a 3' overhang the results are zero overhang. I wonder why this is and if I am missing a step in creating an overhang or where the "overhang" starts.
1 REPLY 1
Thank you for the initial information on creating the roof; can you elaborate on what type of roof you are creating?  By default you should be able to do the following:
1.  Start the roof sketch, pick or add lines.
2.  Specify an Offset of 3’-0”; you should notice the line is offset from the pick or when drawing new lines.
Video Example
Thank you,
Ryan Duell
