Roof Drains and Scuppers
5 REPLIES 5
8428 Views, 5 Replies
Has anyone ever created a roof drain and a scupper to be placed in a roof and wall respectively?
5 REPLIES 5
fraquarc
Sorry I'm a new user and I have the same question! Did you find a way, or have a reply?
You can create a roof hosted family and a wall hosted family to meet the needs of you roof drain and scupper.
You might check Revit City or AUGI for family content to see if anyone has created one of these families that meets you need.
Mel Persin, AIA
sbrown
Yes, I have made a wall based family that contains an opening that cuts the wall with height parameters to locate the opening, it then has a conductor head and downspout.
regalith
in reply to: sbrown
This family is exactly what I'm looking for except the insert point is way above the object so I can't insert it into a wall at the correct height.  I can insert it into the model but when I try to move it up to the correct height I get a warning that the family isn't cutting anything.
dcarlsen8GY35
in reply to: sbrown
Can't thank You enough - just stumbled across this and it is perfect. I had that cutting issue too but realized I was trying to put it in to a parapet beyond.
