This family is exactly what I'm looking for except the insert point is way above the object so I can't insert it into a wall at the correct height. I can insert it into the model but when I try to move it up to the correct height I get a warning that the family isn't cutting anything.
Can't thank You enough - just stumbled across this and it is perfect. I had that cutting issue too but realized I was trying to put it in to a parapet beyond.
