Hi I am still new to Revit. I have modeled a subway station, now I want to sweep a tunnel down the centerline of the rails. what is the right tool for a job? I can't find a sweep option of In-Place Mass. Just FYI the tunnel section has two closed loops to define the wall thickness with a void space in the middle.
If you want to make a sweep in In Place Mass, simple create a closed shape in a vertical named Reference Plane and a Model Line (can be a series of lines and curves with the first segment perpendicular on the vertical Reference Plane) in the horizontal Floor Plan , perpendicular onto the named Reference Plane. Select the shape and the line and Modify > Create Form > Solid Form
Then , in Project >Architecture > Wall by Face
https://screencast.autodesk.com/main/details/e1c79c98-44ce-4efa-bf74-3151161bc58a
in the bottom image an example of sweept mass with a curved path:
Constantin Stroescu
