I am running Autodesh Revit 2013 on a Lenova Z580 notebook. Operating system is Windows 8 Pro. There is an issue with how the ribbon functions. An example is if I do a multi-select and then exit that command, and then want to add a component, when I click on component the "Modify/Place Component" doesn't appear - It appears as the previous commands icons (eg "Modify/Select). The only way to get it to show the correct icons is to cycle thru the ribbon view options.
I have tried to delete the UIState.dat file but that doesn't work either. Anybody got any ideas?
Solved by Jason_S. Go to Solution.
Do you have Update 2 installed? That fixed all the ribbon problems I had with Windows 8 and 2013.
Here are the links:
If you have Revit without a suite go here to download:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9273944
If you have Revit Building Design Suite go here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679039&linkID=16831210
