Revit Architecture
Member
steveterhune
Message 1 of 4 (664 Views)
Revit won't start
664 Views, 3 Replies
10-19-2012 10:47 AM
I am unable to start Revit. I have installed, uninstalled over and over and still get a window showing an exclamation point in a yellow triangle. I tried to install 2012 and that wouldn't work. It was looking for a file when it said it still had 5 of 8 steps to go.
I did download the update. Even tried downloading from the site rather than my disks.
Same problem with Autocad and Architecture.
I have a 64-bit machine. Revit 2012 has worked previously on this computer.
*Expert Elite*
Bob_Zurunkle
Message 2 of 4 (622 Views)
Re: Revit won't start
10-22-2012 08:53 AM in reply to: steveterhune
I think others who have had installation problems have been advised to completely uninstall the program first, using revo-installer or something like that. Search these forums for similar problems, to get the exact info. You should also be able to get installation help directly from autodesk. Thirdly, there's a licensing forum here that is for exactly these kind of quesitons :smileyhappy:
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Member
steveterhune
Message 3 of 4 (615 Views)
10-22-2012 10:18 AM in reply to: Bob_Zurunkle
Thx Bob. I had uninstalled using the normal method thru Autodesk software. I decided to take your advice, reinstall Revit (which again didn't work), then use Revo to uninstall again. Well, Revo doesn't even see Revit! It worked when I wanted to uninstall Design Review, and did a great job with that. Very puzzling, and keeping me from working at this point.
Product Support
alan.quinn
Message 4 of 4 (588 Views)
10-23-2012 05:10 AM in reply to: steveterhune
Try a clean install and reinstall. Removing Revit from the Control Panel > Add/Remove Applications does not remove the entire application. Please read over and carefully follow all the instructions.
2013: How to Complete a Clean Install [Uninstall] of Revit products
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18782231&linkID=9243099
Hope this helps and thanks for posting.
Alan Quinn
Support Specialist
Product Support
Autodesk, Inc.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
