Revit to RAM Export
1 REPLY 1
946 Views, 1 Reply
Revit to RAM Export
Is there a solutiion for exporting a skewed model from Revit to RAM and have this model be rotated about an axis to be vertical and horizontal on the screen for use with Revit.  First I assume the problem to be with RAM and be thiers to fix but i am checking here also.
1 REPLY 1
fernanda.firman
This workflow would be better explained by Bentley since they are the one who owns and designs the link between those 2 programs.
Here is a link that might answer your question:
http://bim.wikispaces.com/Revit+RAM+Interoperability
2. Can you send changes from a Revit model to RAM Structural Systems after the initial structural analysis?
Yes, it is possible to change your Revit model after the initial export to RAM. To do this, export from Revit to RAM like you did the first time; however, this time be sure to select the box that says "Perform deleates on re-export." Your model should successfully be re-exported to RAM with the original selections saved. RAM is ready to re-design based on the Revit changes!
3. Can you send changes from a RAM model to the original Revit Model?
Yes, revisions can be made to your RAM model and successfully be imported back into Revit. Simply select to "Update Existing Model" and "Perform Deletes from RAM."
Hope that helps.
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
