Revit structure / architecture 2015
6 REPLIES 6
xczgordon
375 Views, 6 Replies
Hi. I don't know how I can down load revit structure and / or architecture. I can only find update files in this website but not the original installatin files.
Thanks for your help.
6 REPLIES 6
Jason_S
in reply to: xczgordon
http://www.autodesk.com/products/revit-family/free-trial#
This link takes you to the trial download.  You can use it to download and if you have an authcode use it when you first open Revit and it asks if you want to authorize or continue trial.
Hope this helps.
xczgordon
in reply to: Jason_S
Thanks sir. Does that mean Revit and Revit structure / archetecture is the same thing? Thnaks.
Jason_S
Yes Sir,  That is the link to the version that has Architecture, MEP and Structural.
Enjoy!!!  Also, Welcome to the forum.  You picked a great place to get help and information.
xczgordon
Thanks. I have installed Revit 2015. How can I identify different component, eg structure or architecture? Thanks.
Jason_S
On the ribbon you should see architectural, systems and structural tabs.
When you pick on those the tools for those disciplines will show.
xczgordon
Thanks.
Rail Community
