I am running Windows 7 on my late 2008 MacBook Pro with a 2.4GHz Intel Core 2 Duo processor and 4GB of ram, but each time I lauch Revit it loads my file just fine and then crashes. Does anyone else know about this issue and know a possible fix for it? I tried both the 32-bit and 64-bit verisons and they both came to the same result.
Quick responces would be great as this would help me get work done for finals quicker.
4 gigs may not be enough
how big is the file?
DarrenP
The file is around 8MB but I had my friend look at it and we came up with that Windows was only using an 8th of the ram I had. So a quick change in the VRAM settings to have it use all of it and now its running like a champ.
