Show only
Search instead for
I am creating a scale model for a laser cutter using 1/4" mdf. So my drawing needs to be 1/4". How do we change the Revit custom scale to 1"=1/4" OR 1/4" = 1/4"?
About the first question, the ratio for 1" = 1/4" would be 1 : 0.25 ; which is not possible in Revit. The ratio must be a positive integer.
Your second question, about 1/4" = 1/4", the ratio would be 1 : 1 ; then, select 12" = 1'-0" , which is the same. That is the highest detail possible in Revit.
Alfredo Medina _________________________________________________________________ ______ Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
