Revit export to DWFx for Design Review - Orientation issue
1 REPLY 1
KayChrisKay
332 Views, 1 Reply
Greetings!
I am currently trying to export a Revit-project including sheets in different formats, (currently A3 and A4), however, the orientation on the sheets vary. When I want to export to Design Review in DWFx format, I'm using the "<Use Sheet Size>" paper size function, which works like a charm. However, it doesn't autodetect the sheet orientation, and cuts off the top of the sheets if I'm using Landscape, and cuts off the sides if I'm using Portrait.
Currently, I have to export twice (both in landscape and portrait), and manually drag and drop sheets back and forth in Design Review in order to get a DWFx with all sheets oriented correctly.
Is there any way to auto-detect sheet orientation, or maybe a whole other solution?
(Sorry for bad english)
1 REPLY 1
ennujozlagam
in reply to: KayChrisKay
try to configure from here. please see attached
