Revit dimensions at ridiculous precision
2 REPLIES 2
5283 Views, 2 Replies
As I was checking something with shared coordinates I had the units decimals set to 0.000000000001 I noted some odd behaviour with the dimensions. The dimensions values seem to change with the position of the mouse (during placing them). It's not really a problem since normally I would never set the precision this way. It's just a bit of odd behaviour.
please take a look at the images from my blog
http://danielgijsbers.blogspot.nl/2014/06/revit-make-up-your-mind.html
Tags (1)
2 REPLIES 2
Please set your units in Revit file. Just type "UN" and then set it as per your requirement. Hope the problem will be solved.
thanks & regards,
Subhradeep Sen
Kolkata
India
Thank you Subhradeep,
I didn't really want a fix because I know how to set the units. I just wanted to point out there is something odd going on when you set the units to absurd precision.
