Has Autodesk updated Revit software to run in Windows 8.1? I have had no luck installing on a new computer that has Windows 8.1.
As with Windows 8 you have to install .NET Framework (includes .NET 2.0 and 3.0) before you can install Revit.
Go to Control Panel --> Click on Uninstall or Change a program --> on the left click on Turn Windows features on or off.
A window will open check the box to the left of .NET Framework (includes .NET 2.0 and 3.0) then click OK
This will install these features which will allow you to install Revit 2014, 2013 and 2012. i have not tried to go any lower than 2012 for Revit.
Been using Windows 8.1 since its release without issue.
Please remember to install all the updates for Revit.
Hope this helps you out.
I've gotten a successful install message from Revit but when I go to my programs it's not there. I tried adding the .NET as above, but now it's saying that Revit is already installed. It's not showing up as a program or in the interface under apps.
