Revit Won't Install
2 REPLIES 2
426 Views, 2 Replies
Revit Won't Install
Im trying to dowload Revit Extensions for Autodesk Revit 2014.  I get an error message everytime that reads:
Module C:\Program Files\Common Files\Autodesk Shared\Autodesk Concrete Building Structures Engine 2014\CBSGeoLoad.dll failed to register. HRESULT -2147024770. Contact your support personnel.
I've downloaded it as an administrator as well and I get the same thing.
Can anyone help??
2 REPLIES 2
TravisNave
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Make sure your anti-virus is temporarily disabled as well.
Good Luck!
Autodesk Forums:
Hello, I have problem installing Revit 2014 (student version) for windows 7 64 Bits, I have the requirements, also I have disabled antivirus. When it is installing it doesn´t finish, and i have been waiting hours and hours.
If any one can help me pls.
