Hy everybody,
My name is Vitor Alves, i'm modeling un hold house and one of the exterior walls have variable thickness.
I don´t need two walls with different thicknesses but just one that is changing is own thickness along his development.
Thank you
Solved by GHASEM_ARIYANI. Go to Solution.
Hi
If I understand your question correctly, you can use the following method to Ajam.
1-Stacked Wall
2-Select model In Place and then Select wall and Using Tools Blend or SweepBlend Draw
Thank you so mutch! That was exactly what i was looking for!
you have almost saved my life;)
tnhank you once again
