Hey everyone,
I receive this error when we try to install this Revit update from here.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=16841348
We downloaded this install from the website of Autodesk and have kept a original installer locally on the c drive in the default location Revit extracts. Is there something I can do fix this.
Mike
You may want to try posting here....
http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
They may be able to assist more...
Also have you contacted your reseller for assistance?
Are you on subscription? If so you can access autodesk technical assistance directly to help with this issue.
LD
