Revit Update #2 install problem
4 REPLIES 4
Gyvven
277 Views, 4 Replies
I've finally gotten around to installing the update. Unfortunately it isn't working. We have a network installation and when I start the update exe it brings up the dialog box that asks you to locate the Autodesk_Revit.msi. I've tried browsing to it on the network and it won't go. I've tried inserting the DVD, won't go. I've copied the msi to my local, it still won't go.
The Autodesk solution was to try the items above and that was the only mention I could find. Does anyone have any other ideas I could try?
4 REPLIES 4
in reply to: Gyvven
You may need to install the full version of WU2,
also availabe for download on the website.
I've
DVD, won't go. I've copied the msi to my local, it still won't go. The
I also have a problem with the installation of Update 2.
If I start it, It just stops after the first seconds and doesn't make anything anymore. I always have to forcefully shut it down.
I don't know what the problem could be, but I need this update so that I can install the add-on for online rendering.
Any ideas how I can install it?
parveen.revit
try after downloading it again.
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
in reply to: Gyvven
Already did that several times.
Doesn't work either.
