I have finally gotten around to re-creating our CAD title block in Revit. With a sheet open from a current project in Revit, I am looking to remove and or re-order some of the fields from "Identity Data" under properties both of the sheet and of the title block (the fields are the same but in a different order). I'm also wondering how I can control which fields show up in this list. I'm a total beginner when it comes to creating Revit title blocks, and have basically just created something that works, and now I want greater control over what each of us architects in my office will see when filling out these fields.
Hey Chad,
1st Question is which version are you using? In 2014 and earlier, you have no control as to sorting order of Params. In 2015, in thte Family Editor, the Factory added that ability.....I haven't tested that on ALL families, specifically on TB types, but I would assume that it is accross the board. So if you're not on 15, you pretty much stuck.
HTH
Mike.
