Revit Architecture
Active Member
mathijs.maertens
Message 1 of 14 (1,020 Views)
Revit Server 2012 installation error
1020 Views, 13 Replies
10-03-2011 07:52 AM
when I try to install revit server 2012, I get an error "there is a problem with this windows installer package. A script required for this install to complete could not be run.  Contact your support personnel or package vendor.
When I check the install log, it has this error:
"InstallRevit ServerFailedInstallation aborted, Result=1603"
This is on a server 2008 R2 and all prerequisites have been installed.  Anybody experienced this problem before?
Product Support
alan.quinn
Message 2 of 14 (989 Views)
Re: Revit Server 2012 installation error
10-04-2011 10:11 AM in reply to: mathijs.maertens
A few things may be causing this. See this link and pay particular attention to #1: http://revitclinic.typepad.com/my_weblog/2011/05/3-revit-server-2012-installation-tips.html. Also, if this is not the case I’d go back and check the prerequisites, .net, etc...
Thanks for posting.
Alan Quinn
Support Specialist
Product Support
Active Member
mathijs.maertens
Message 3 of 14 (963 Views)
10-06-2011 01:18 AM in reply to: alan.quinn
thanks for the reply.
Indeed we are running the setup this way and I double checked prerequisites
After googling, I tried solutions from the following links, but non of these files/reg keys are present
http://upandready.typepad.com/up_and_ready/2011/08/windows-the-hklm-software-autodesk-registry-key.h...
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16828836&linkID=9243099
I checked the anitvirus logs: nothing is being blocked.  I also tried to run the setup on a test server with an identical antivirus / group policy and there the installer runs fine so I've excluded anitvirus / group policy.
I deleted everything in the %temp% folder
Disabled UAC, no success either.
Really stuck here...
Active Member
mathijs.maertens
Message 4 of 14 (923 Views)
10-10-2011 11:24 PM in reply to: mathijs.maertens
Installed 2008R2 Service pack 1 but unfortunately the installer still errors out
Could it be a problem that LMTools is already installed/running on this server or that Revit is not installed?
Even our vendor has run out of ideas...
Product Support
alan.quinn
Message 5 of 14 (907 Views)
10-11-2011 08:18 AM in reply to: mathijs.maertens
I asked our Revit Server lead to take a look at this one. I will update when I hear back from him.
Alan Quinn
Support Specialist
Product Support
Active Member
mathijs.maertens
Message 6 of 14 (877 Views)
10-14-2011 04:17 AM in reply to: alan.quinn
looking forward to the feedback, thanks
Active Member
mathijs.maertens
Message 7 of 14 (785 Views)
11-02-2011 07:32 AM in reply to: mathijs.maertens
hello Alan, any news from the revit server lead?
Product Support
alan.quinn
Message 8 of 14 (769 Views)
11-03-2011 08:54 AM in reply to: mathijs.maertens
Sorry for the delay in getting back to you. We have a meeting this afternoon and I will be brining up this case. I'll let you know what I find out.
Thank you,
Alan Quinn
Support Specialist
Product Support
Product Support
alan.quinn
Message 9 of 14 (735 Views)
11-10-2011 01:19 PM in reply to: alan.quinn
Try the following:
[1] Clear out %temp%
[2] Run the RS install again
If you still have issue
[3] Collect everything in %temp% and send to ADSK for further analysis. (We'll figure out how to do this later)
Thank you,
Alan Quinn
Support Specialist
Product Support
Active Member
mathijs.maertens
Message 10 of 14 (697 Views)
11-15-2011 07:59 AM in reply to: alan.quinn
ok I tried deleting everything in the %temp% folder once more, however the error remains.
Where shall I send the zip file?
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
