Revit Roof Soffit Tag - Missing family tag template
11 REPLIES 11
Message 1 of 12
boo2u20
2773 Views, 11 Replies
I need to tag my roof soffits, exactly the same way I tag my ceilings to show the height. At present, I have tried to use a ceiling, roof, and multicategory tag to tag a roof soffit and it does not work!!!
Autodesk, how do you tag a roof soffit? Can you please send me a roof soffit tag.rfa to start from? The category does not exist in the OOTB family templates.
HELP!!
11 REPLIES 11
Message 2 of 12
loboarch
in reply to: boo2u20
Roof soffits are not taggable elements in Revit.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 3 of 12
boo2u20
in reply to: loboarch
What is your reasoning for not making roof soffits taggable elements?
If ceilings are taggable, intelligent parameter-reading roof soffits tags would save time using the same parametric intellegence.
Message 4 of 12
loboarch
I do not know the history of why soffits are not taggable elements?  If you would like to suggest this as an improvement you can send our team feedback at this link and this can be something considered for enhancement in a future release.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Jeff Hanson
Revit Help |
Message 5 of 12
Cftreat
If you cant tag them then why in the world do they have Mark and Type Mark Paramenters. Get with the "Program"
Message 6 of 12
oh dear. just another item to add to the list of Revit and Autodesks fundamental misunderstanding of their own product. If wish list items actually came true....
Message 7 of 12
R2020 and STILL unable to tag soffits.  Quite frustrating, especially because you CAN create a tag for the Roof sub-category, so you're let wander down a path that then you can't implement.
Very disappointing.
Message 8 of 12
ihakki6991
Perhaps soffits should be removed so we don't model what we cannot tag.  Is there a way to covert soffits to ceilings?
Message 9 of 12
in reply to: ihakki6991
Create parts and tag parts.
Message 10 of 12
ihakki6991
in reply to: ToanDN
That's a brilliant workaround!
Message 11 of 12
kalsayyed
You always can edit an existing family (ceiling or roof for example) and update "Family Category and Parameters" to be whatever you want (Roof Soffit Tags for example). Now you have an annotation family for Roof Soffits, where it recognizes Roof Soffits.
Best of luck
Message 12 of 12
Alfredo_Medina
I agree. There should be a Soffit Tag family, and a Soffit Tag category. (Using Revit 2023). Or at least the category and a property set, so that the user can create the family, if it is not included in the library.
I was able to tag it using a keynote tag, but, it would be better to have a soffit tag, to be consistent with the same methods used to tag other things, such as ceilings.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
