Is there a way in Revit to export or import settings much like a profile in AutoCAD and how I set up the icon to point at that profile when the program opens? I would like to know how be able to customize where the program looks for the families and other items over the network, so all users can see the same thing, in options.
Attached is the properties of the AutoCAD icon. The Target is set-up to point to the "AutoCAD Architecture (US Imperial)" profile. I would like to do something similar in the Revit icon.Those kinds of things are mostly held in the Revit INI file. This file is "per user" on the machine. If you want everyone to have the same settings you have to push the INI file into each users folder. Then when Revit starts it will use these settings.
