When I export my model from Globe Link add in, it gives me the option of including linked files. I select this but in the kmz google earth file, the links do not show? I have changed locations in the linked models and everything.
Solved by Alaaeldin_Alsahli. Go to Solution.
Globelink will detect all ID elements in the file including Analatical element but it doesn't mean it will be able to export to KMZ. Globelink is not able to regenerate what inside the revit link but it knows where the insertion point of this link is
The best workflow for your question is the fallowing
https://chronicle.autodesk.com/main/details/d20b4029-0bb3-4ae2-a7ee-0e56c7345913
You could always login a wishlist asking for some improvement related to this add-in (GlobeLink) but for now i suggest you to go with this workflow
