Revit License issue
1 REPLY 1
rocyr
164 Views, 1 Reply
Revit License issue
I wanted to move a stand alone license from one computer to another. I incorrectly uninstalled revit on the first computer installed of using the licence utility. How can I now move revit from one computer and re-license it on the new computer? Should just re-install on the first computer and try to use the license utility?
Thanks in advance, Roland
1 REPLY 1
TravisNave
in reply to: rocyr
Please do not double-post.  You can have an Admin move a post for you if necessary.  I have responded here:
http://forums.autodesk.com/t5/Installation-Licensing/Revit-License-Install-issue/m-p/3439063
Thanks!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
