Using Revit LT 2014, I'm trying to make the colours used for a room colour scheme transparent. Is there a way of doing this?
Solved by bcarriere. Go to Solution.
Stuart I think your only option is Color Scheme Location which can be set to foreground or background. There are no visibility graphic overrides for Rooms - Fill Color.
bev
Thanks for the information. I have to say this is a shame and should be added to someones wishlist. I use transparency a lot with other programs, which works well, and means that the colour is not to 'in your face'!
Maybe I miss something.....but the override by element and by category works for transparencies...
Your Name
Yes..I missed you were speaking about LT ...maybe it doesn't work for LT...sorry...
Your Name
Constantin, that does work!
I had been trying to adjust the transparancy via visibility graphic - Rooms - Color Fill element only. But you CAN apply transparancy to the Rooms, and this will apply to room color schemes in Revit LT!
Stuart, I think this is what you are looking for.
