Using Revit LT 2014, I'm trying to make the colours used for a room colour scheme transparent. Is there a way of doing this?
Solved by bcarriere. Go to Solution.
Stuart I think your only option is Color Scheme Location which can be set to foreground or background. There are no visibility graphic overrides for Rooms - Fill Color.
bev
Thanks for the information. I have to say this is a shame and should be added to someones wishlist. I use transparency a lot with other programs, which works well, and means that the colour is not to 'in your face'!
Maybe I miss something.....but the override by element and by category works for transparencies...
Yes..I missed you were speaking about LT ...maybe it doesn't work for LT...sorry...
Constantin, that does work!
I had been trying to adjust the transparancy via visibility graphic - Rooms - Color Fill element only. But you CAN apply transparancy to the Rooms, and this will apply to room color schemes in Revit LT!
Stuart, I think this is what you are looking for.
