I am trying to get acquainted with Revit LT. I have been using Autocad for a 30 years now so it is like a comfortable shoe. Revit not so much but I see great potential. I business is residential plans for builders that need floor plan options. I am attempting to create design options, which help tells me is available but I do not have the design option tab in the manage area as described. I am beginning to believe that is one of the things that differentiate between Revit and Revit LT. Can anyone provide me with information?
Thanks ...
Solved by damo3. Go to Solution.
Thank you .... It worked. It did take me awhile to figure out how to get to the options. Not having a command line - old habits are indeed hard to break!!
Your welcome. glad it helped.
I also cannot see "Design Options" and it does not show up as a tick box under User Interface. Is there any other setting or place it might be in Revit LT 2014?
@uelsam1 wrote:I also cannot see "Design Options" and it does not show up as a tick box under User Interface. Is there any other setting or place it might be in Revit LT 2014?
I had the same problem, just finding the tick box. I have attached a couple screen shots as well. You have to go to options on the "open" screen, its at the bottom right center. That will get you to the correct user interface screen (the second screen shot).
I hope that helps!!
