I have Revit LT 2013 and I'm planning to buy new computer for it. I am wondering, which operating system I shall choose. On the website with system requirements for Revit LT I can see that 2013 version is not supported on Windows 8. However I found the theard (http://forums.autodesk.com/t5/Autodesk-Revit-Architecture/Revit-2013-windows-8/td-p/3779302) saying that with some update Revit 2013 runs perfectly fine on Windows 8. Does this update is also available for Revit LT 2013? Does Revit LT 2013 will work correctly on Windows 8?
Solved by loboarch. Go to Solution.
The update is avaliable for Revit LT 2013 as well. Revit LT 2013 will run on a PC running Windows 8 with no difficulties once the update is applied.
