Revit Architecture
Active Contributor
bcarriere
Message 1 of 5 (674 Views)
Revit LT 2013 & Residential Framing
674 Views, 4 Replies
12-10-2012 08:46 AM
Has anyone completed a residential roof framing plan with Revit LT? If so, will you please share with me how you did it.
Active Contributor
bcarriere
Message 2 of 5 (640 Views)
Re: Revit LT 2013 & Residential Framing
12-11-2012 02:29 PM in reply to: bcarriere
OK, Anyone using Revit know how to do residential framing (floor & roof framing) in Revit LT?
Please note in Revit LT there is no "beam system" icon/option.
Employee
loboarch
Message 3 of 5 (619 Views)
12-12-2012 10:30 AM in reply to: bcarriere
You can place individual instances of a beam (or other framing member) and then use the array command.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
Active Contributor
bcarriere
Message 4 of 5 (602 Views)
12-12-2012 05:28 PM in reply to: loboarch
Jeff,
Thanks for the reply! So, in this case, using Revit LT is no different than using AutoCAD (copy and/or array) with the exception that when the beams are arrayed they show up in all applicable views?
Valued Contributor
Irish2
Message 5 of 5 (594 Views)
12-12-2012 08:57 PM in reply to: bcarriere
Yes plus they are 3D. Move it in any view it changes in every instance. You can move the arrayed set or individually.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
