So me and my company have received a Revit file as part of a handover.
We've got full access to the data and are trying to edit a few things and I have a few questions:
- There are a number of SHARED parameters within the file
- There is no shared parameter file - can i create one using the shared parameters already present?
- Can I edit these shared parameters in any way? (Name, type of field to text from number for example)
Piestar
Using Autodesk Revit Architecture 2014
Solved by BIMgirl. Go to Solution.
