Revit DB Link Error
4 REPLIES 4
bbrown
1797 Views, 4 Replies
Revit DB Link Error
I am getting an error when exporting my Revit project to Access 2010. I am only getting this error on this file, the utility works on other files. Any help would be appreciated.
Tags (1)
4 REPLIES 4
bbrown
in reply to: bbrown
I have also tried setting up a DSN to Access through ODBC and I get a different error now, but it appears to be from the same thing. From this error it appears that Revit is trying to put values into columns that have a fixed size and the values are too large. The trouble is I can't figure out what these values are.
Lance.Coffey
in reply to: bbrown
Try reviewing the journal recorded by Revit for more information on the error.
The following document has information on the location of the journal files:
Location of journal files
http://usa.autodesk.com/getdoc/id=TS1067426
The following blog posts have information on reading journal files:
http://revitclinic.typepad.com/my_weblog/2009/03/a-journal-file-story-part-1.html
http://revitclinic.typepad.com/my_weblog/2009/03/a-journal-file-story-part-2.html
http://revitclinic.typepad.com/my_weblog/2009/03/a-journal-file-story-part-3.html
http://revitclinic.typepad.com/my_weblog/2009/03/a-journal-file-story-part-4.html
Lance Coffey
Technical Support Specialist
bbrown
in reply to: Lance.Coffey
Here is the journal file. The program freezes without throwing the error in the journal. I am going to try deleting Generic families to see if that helps.
bbrown
in reply to: bbrown
I deleted the Windows families ( a louver) and it worked. It took it 25 minutes to export the database and showed in Windows as not responding the entire time.
