I have been working on a model for over 2 months now and a week before a CD set is due the model crashes everytime I try to place a new view on a sheet. It is fine at all other time but whenever I try to place a view I receive a fatal error message. Other projects are working fine in regards to this. Any idea as to why this is happening?
Have you run an audit on the model? There maybe something in the model that is wrong. On the open dialog box you can click the check box for an audit. It will come up with a warning that it will take a long time - but usually does not.
LD
Does this occur for any user working on the Project? If there are no other users, have you tried doing this from another computer? This will at least tell you if the problems lies with your machine or with the Project.
