During a save, Revit saved the file to C:/Temp before saving to the server. After running out of temporary space on the local drive, Revit crashes. Then tells me that no recovery file will be made because I recently saved. The problem is, it never saved to the server and the last (recent) save was 2 hours prior.
WHEN would you ever NOT want a recovery file????? Who cares if I saved 5 min. ago, it should ALWAYS default to creating a recovery file. This is a MAJOR, MAJOR problem.
