Revit Configuration File
2 REPLIES 2
jwolfer
656 Views, 2 Replies
Greetings,
Just got Revit 5.1L (havent rolled out 6 yet). Ideally, I would like to configure 1 PC to use certain options (drive mappings to support files, etc). Is there a config file for revit that if I copy it to other PC's the mappings to the libraries on the network will be already mapped?
Thanks!
2 REPLIES 2
in reply to: jwolfer
look at the revit.ini file in the program directory "jwolfer" wrote in message news:32344393.1074196462929.JavaMail.jive@jiveforum2.autodesk.com... > Greetings, > > Just got Revit 5.1L (havent rolled out 6 yet). Ideally, I would like to configure 1 PC to use certain options (drive mappings to support files, etc). Is there a config file for revit that if I copy it to other PC's the mappings to the libraries on the network will be already mapped? > > Thanks!
reubencooke
REVIT.INI file
