Revit Architecture
jwolfer
Message 1 of 3 (349 Views)
Revit Configuration File
349 Views, 2 Replies
01-15-2004 11:52 AM
Greetings,
Just got Revit 5.1L (havent rolled out 6 yet). Ideally, I would like to configure 1 PC to use certain options (drive mappings to support files, etc). Is there a config file for revit that if I copy it to other PC's the mappings to the libraries on the network will be already mapped?
Thanks!
*Greg Cashen
Message 2 of 3 (349 Views)
Re: Revit Configuration File
01-15-2004 12:01 PM in reply to: jwolfer
look at the revit.ini file in the program directory "jwolfer" wrote in message news:32344393.1074196462929.JavaMail.jive@jiveforum2.autodesk.com... > Greetings, > > Just got Revit 5.1L (havent rolled out 6 yet). Ideally, I would like to configure 1 PC to use certain options (drive mappings to support files, etc). Is there a config file for revit that if I copy it to other PC's the mappings to the libraries on the network will be already mapped? > > Thanks!
Distinguished Contributor
reubencooke
Message 3 of 3 (349 Views)
01-21-2004 08:57 AM in reply to: jwolfer
REVIT.INI file
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
