Revit Batch Plot / Export to PDF & DWG
2 REPLIES 2
miguelmm
4066 Views, 2 Replies
I am looking to know if there is a 3rd party plugin / add-in (or if autodesk do it) which will do the following:
  1. Batch plot different page sizes and orientation to PDF, individual files prefereable
  2. Batch export the same pages to DWG format, preferabbly at the same as the PDFs
  3. Allow for custom naming to suit our office standards.
I have seen and tried a number of add-ins on the autodesk exchange and all fall short, even the autodesk add-in for batch plotting.
This is a large gap which autodesk has built within Revit and should be sorted sooner rather than later as its is out there for other platforms and consumes a large amount of time and effort if having to print multiple time....
Thanks.
2 REPLIES 2
scott.a.green
in reply to: miguelmm
   Here are some Apps I found that should work for you:
   1. SOFiSTiK 3D-PDF Export 2014 (64-Bit) .RVT to .PDF
       https://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3asofistik3...
   2. RVT Xporter - .PDF to .DWG
       https://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3artvxporte...
   3. CTC BIM Project Suite 2014 - Custom Naming
       https://apps.exchange.autodesk.com/RVT/en/Detail/Index?id=appstore.exchange.autodesk.com%3actcbimpro...
   I hope this helps with what you are looking for.
First Name Last Name or First Name.Last Initial
Public Facing Job Title
Link Name | Link Name | Link Name | Link Name
miguelmm
in reply to: scott.a.green
Hi Scott,
I have looked at RVT exporter before and the batch plot function is similar to Revit in regards to different paper sizes, so doesn't work for me.
I have actually discovered Xrev Transmit which does everything I need.
Miguel
