Revit Backwards Compatibility
49 REPLIES 49
Message 1 of 50
bobmayflower
12287 Views, 49 Replies
Does anyone know what Autodesk plans to do about the backwards compatibility issue with Revit?  I have Revit 2012 but I have to use Revit 2011 because the software is incapable of saving back a release.  This is total craziness!  Why would anyone knowingly upgrade with this being the case?
49 REPLIES 49
Message 21 of 50
octavio2
in reply to: scott_d_davis
Just curious, which are the other BIM softwares other than Revit and Archicad that can be used for architectural work (design, production, etc?).
Message 22 of 50
bobmayflower
in reply to: octavio2
The only BIM programs I know of are listed below.  I believe ArchiCAD was the first to support BIM technology.  Revit is the only BIM software I’ve actually used.  In my opinion BIM technology is still a relatively new technology in an industry that adapts to new technology relatively slow when compared to other industries.  In other words there are a great many users out there that don’t use any kind of BIM technology at all.  Despite what Autodesk would have you believe, backwards compatibility is a big hurdle for content (family) creators.  Content creators that use Revit have little incentive to upgrade.  Content creators, who don’t use Revit or BIM at all, will hesitate to go to Revit because of the backwards compatibility issue.  I want Revit and BIM technology to be the standard, and believe it’s a better solution for architectural design than non-BIM software like AutoCAD and others.
BIM Software:
ArchiCAD
Bentley Systems
Revit
VectorWorks
Message 23 of 50
in reply to: bobmayflower
I like to be up to date to the minute with my software, however, coordinating an upgrade on a large project, with large consultant firms, results in that project staying in the version it was created in. There is no way to have an entire team and the teams of all the consultants upgrading at the exact same time. Some of the reasoning in this article doesn't pan out. Someone said to coordinate with consultants the life cycle and version of revit the project will be in. We don't know who the consultants are going to be until far into the design of the project. Recently we passed our 2012 model along to the architect working on the TI for our building and neither them or their structural engineer are on 2012 yet. This forces them to use CAD to start while they figure out the politics of upgrading at a large firm, resulting in finishing their work in CAD. I understand making Revit not downgradable, but it seems unreasonable not to do so for at least a single release as you wait for consults, coworkers, and anyone else involved on the project to upgrade.
Message 24 of 50
rosskirby
If you don't know who you're going to be working with, then perhaps you should consider starting in a release prior to the most current release.  You (or they) can always upgrade the model to the latest release if necessary.
This point has been brought up before, but I'll mention it again.  A vast majority of firms that use Revit are on subscription.  It just doesn't make any kind of financial sense for a firm to not be on subscription.  If you're on subscription, you are entitled to use up the 3 versions back from the current version.  Whether or not you choose to install the newest version is up to you, but it's there.  The only cases I've seen where someone wasn't on subscription were for firms that were sole-practitioners, although even most sole practitioners recognize the benefit of being on subscription.
You're not going to be able to save down a version, ever.  And you're not going to convince Autodesk to make that feature a priority, ever.  People who think they need to downgrade a file represent a miniscule, but vocal (especially in April-May when the new release comes out), minority of Revit users.  So I'm afraid you're out of luck.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
Message 25 of 50
Yeah I know. Nonetheless it is an inconvenience, as with many things with Revit. For the money we pay, the improvements and new features are slow to come, from my perspective I see this issue, and many others as Autodesk's laziness.
Message 26 of 50
chris.kershaw
octavio2 there is no such thing as BIM software BIM is a PROCESS not software, you can use any software you like to create the information you require. Im from the UK & the largest problem Im having is people thinking Revit is BIM and its just not true, hats off to Autodesk sales team though they have sponsored just about all seminars about it so people believe them!!
Message 27 of 50
Revit is BIM, but exactly that "Building" information modeling. Revit does not include Civil, Landscape, Geotechnical, or Surveyors in the process. Revit is by no means a complete start to finish solution. However, Revit is the best solution on the market, I would argue that Archicad and others are not BIM. Most others are a CAD program trying to be a BIM program. Revit is BIM from the start, it is just terribly difficult to sqeesze some information out of it or schedule information such as framing schedules. As I said before, Revit is lacking features and we do not see the number of improvements and mew features we should expect for the money we pay.
Message 28 of 50
I agree with the need for backward compatibility with content and detailing of the very least. The fact that subscription readily provides the software is not enough reason to prevent users from the option of saving information back at least the 3- releases allowed on a workstation with subscription. As a Structural consultant we do not have control over what an Architectural client may chose to use for the version of REVIT on a given project. We can beg and plead (communicate) all we want but generally this does not prevent the use of older versions of REVIT. I like staying current personally but I know that each release takes company overhead to get ready for use thus one of many reasons why not everyone stays current (especially in a down economy). I have standard details and content that are updated and created on an ongoing basis and generally I work in the latest release thus the majority of our new content is in the latest release. However when confronted with a project that will be in an older release I now have no ability to take our latest standard details for use in that project. In my opinion it is not an option for Autodesk to limit a user's flexibility in working with multiple releases. We need the ability to save down details and content for the last 3- current releases of REVIT. This is just a fact for consultants that work with a lot of Architects across the country.
I encourage Autodesk to please respond to this request.
Message 29 of 50
It also doesn't make sense to be instructed to always start a project in an older version of Revit. Why should anyone be limited by the progress of others?
Message 30 of 50
I agree that the backward compatability issue is rediculous.  I do not believe all of the end users are looking at it from a business standpoint.  It is extremely difcult ot justify some of these annual hardware and software costs associated with upgrades.  There is not only CAD software (AutoCAD, Revit, Solidworks) but business application software (Microsoft Office), Server software, Antivirus software, Accounting software, etc.  Know factor in the cost of upgrading hardware Servers, Work stations, monitors, Printer, plotters, etc.  No multiply that by 15-50 work stations, 2-5 servers and the cost to manage it, it takes a good portion of the annual revenue to keep up.  Times are tough an the money does not flow in that easy.  And then on top of it the end users are looking for wage increse as well.  End users need to log at the big picture.
Message 31 of 50
I am an interior designer, and most interior designers I know are quickly becoming loyal users of Google SketchUp. They prefer Google SketchUP over AutoCAD Arch, Revit Arch, and 3Ds Max. This is a trend I see around the country and from speaking with friends abroad (London), internationally too. It seems that Autodesk's Revit and AutoCAD are taking big hits in sales because of Google SketchUP.  With the new and easy to use plug-ins and its user friendliness, alot of former AutoCAD users are shifting to Google SketchUP and Vectorworks. Again, from my experience both locally (Wisconsin) and abroad (London), small firms and some large design firms do not want to switch to Revit. The backwards incompatibility of Revit is one big reason why designers do not want to switch to Revit.
 Autodesk Sales Agent Scott talked about subscription, but he and Autodesk should also look into the fact that small businesses cannot afford to change to a new release every year. While it is important to keep up with technology, it is also important to make a program flexible. Afterall every program is pages and pages of code. If Adobe and Microsoft and even other Autodesk products such as AutoCAD can have backwards compatibility, why not Revit?
Cheers,
Anthony
Message 32 of 50
"designers I know"
People who sketch buildings and interiors are talented artists who use a wide variety of drawing
tools. SketchUp is somewhat popular for that, as is 3Ds Max Design. There are many of these
drawing programs because these artists all like something different for drawing. With the Revit
2010 release, Autodesk expanded the massing tools to allow these artists to work closer to Revit.
No conceptual drawing program is really more popular than another. And either those drawings
will export to a .skp , .dwg, or .rvt, and Revit likes them all to start building a construction model.
Message 33 of 50
The Backward Compatibility Issue is starting to wind me up, I work for a surveying company and we have a subscription where we get the new releases as they come out. I like it seems alot are restricted to using older versions because the majority of our clients do not have subscriptions, It's not just small companies, some of our clients have 10k staff all using autodesk software and they obviosly see it as unfeasable to upgrade 10k licenses of every piece of software their staff use every year I wouldn't dare imagine the maintenence costs of that all of which get passed on to the end client. Not only that I don't think I've ever seen £1000 worth of improvements from one years upgrades, a few tweaks here and there normally, and alot of the time fixing and adding things that really should have been there in the first place.
Most annoying is when our clients aren't properly educated in the software they purchase, we have signed a fair few contracts now where the MD's assume they have the "latest" software even after we say you use Revit 2013? "yes the latest" is normally the reply, we issue a Revit 2013 file to have it immediately sent back to us with a grumpy reply "We can't open this our CAD guys say they need a 2011 version" because they only upgrade every 3 years, so much of my hard work is alot of the time for nothing. They still happily pay and realise their errors and make do with an IFC file imported to their version, but it winds me up when i've spent alot of time and effort building intelligent content that doesn't get picked up by an IFC file.
Just bring Back backward compatibility like in the other software you produce, and stop thinking about ways to Monopolise the market for once, Why not try and provide a really useful product that your clients say, Yeah Revit's fantastic, no complaints here, Sometimes it's not about lining your pockets it's about having a little pride in what you produce.
Flippin Monetized system, it drags us all down!!!
Message 34 of 50
in reply to: xxxJimbobidybone
@Jimbobidybone wrote:
we issue a Revit 2013 file to have it immediately sent back to us with a grumpy reply "We can't open this, our CAD guys say they need a 2011 version"
If 2011 could even OPEN a 2013 file, what would 2011 do with
all that 2013 information, besides choke on it? Think about that.
Message 35 of 50
xxxJimbobidybone
Its not a hard one to think about, it would just omitt the additional information that it can't handle from 2013, as I mentioned I work for a surveying company, all we provide our clients (mainly Architects) is an-As built model, in terms of the models we produce everything in 2013 can be done in 2011, it just handes the information better in 2013 making things a bit more efficient, we don't really add a lot of information to the families add anything that 2013 can do that 2011 can't.
just like all other softwares do they leave iout what they can't understand from newer versions, in the case of our models it would be nothing, but from producing IFC files it loses so much information from families including the parameters, materials, and even basic physical properties like voids.
Perfect world would be that everyone paid for the maintenance that Autodesk bully their clients into. but evidently the reality is that alot of customers do not pay for the maintenance, this is causing a lot of people a lot of grief, and looking through this thread is even turning people away from using Revit.
I just think that they should include backward compatibility, even with a small loss of data that could happen, peaople accept this happens in AutoCAD, Max etc. It would make for a much cleaner end product for Autodesk, make it more saleable, and will redeem a bad reputation the program is getting becauses of it.
Just wish AutoDesk would take more pride in their work rather than thinking how best to be profitable.
Message 36 of 50
RandMan
So I'm not the only one that noticed Subscription gets paid, whether we make a profit or not.  We've had to let a lot of good folks go.  My neck is on the line every day over this Revit deal.  I work in Mechanical design.  We need to be in 2013 for a few reasons.  Now I have to figure out a process to coordinate with a few Arch clients still in 2012.  My firm is fed-the-Hell-up with spending money for no return.  I'm the one who said "Revit is great".  I wouldn't be surprised if they decide to kill the messenger (me).
Message 37 of 50
As I said before, Autodesk is really ignoring the masses out there in the design community who are either independent designers or people who work for small design firms. Even though many users dont really use the programs full capabilities, they are forced to keep up with the yearly releases which is costly.
Maybe it is time for Autodesk to consider a lighter version of Revit and include backwards compatibility in that version? This newer version should therefore be affordable and it will meet the demands of the currently dissatisfied users of Autodesk's Revit.
Or is this already being considered by Autodesk, and that's why AutoCAD Architecture is starting to look and function like Revit? The new AutoCAD Architecture 2013, in my opinion has many new features that were previously only available in Revit.
Message 38 of 50
rosskirby
Sigh.  Fine, I'll bite.
Revit can be exactly as backwards compatible as AutoCAD can.  If you export a CAD file from AutoCAD, then you're just exporting lines to lines.  No problem.  If you're exporting from AutoCAD Architecture to a previous version of vanilla AutoCAD (i.e. an AutoCAD release that is pre-ACA), then you get just that, CAD.  Not walls and doors, but lines and blocks.  A dumbed down version of what you had previously, with a ton of lost functionality.
The same is true for Revit.  You can't "save down" per se, but you can export to IFC, and then re-import that IFC file into a new Revit file from a previous version.  Will it import and open?  Yes.  Will it be exactly the same and fully functional?  No, probably not.
While you may consider this inconvenient, or some great travesty, it is not.
Ross Kirby
Principal
Dynamik Design
Message 39 of 50
RandMan
in reply to: rosskirby
Ross, sorry I'm so long getting back to you.  Your solution does work.  Most of the coordination between consultants (that I do) concerns the location of various components.  The most important data for this task (X, Y, Z) didn't change.
Message 40 of 50
Overall Revit falls short with many issues. One of which are the fact that autodesk continues to issue new versions each year and forcing people to pay for the subrscription or pay for a complete upgrade. There is no need to issue small changes year after year that are often full of bugs. Instead perfect the version and release a new version every 3 years. Another issue is its compatability with deciplines outside of mep, structure, and architecture but that is a whole other topic.
