Revit Architecture 2015 UR1 Patch error
29 REPLIES 29
Message 1 of 30
BIMologist_
4138 Views, 29 Replies
Revit Architecture 2015 UR1 Patch error when you download the Patch during the installation. I have created a support ticket with adesk. Is anyone else getting this?
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
29 REPLIES 29
Message 21 of 30
tskramer
in reply to: Tony_Michniewicz
Much appreciated Tony! Thanks for the quick response.
Message 22 of 30
nick.beaven
in reply to: BIMologist_
Heres another one for you - we have built adminimages for Revit 2015 from the BDSP download with the automatic update feature disabled (as we like to manage the download / install process for our typical 700+ installs of Revit per version). The build of Revit from the BDSP package is again: 20140223_1515(x64), without having the application manager installed how can i get the UR1 patch downloaded as it doesnt appear on the http://knowledge.autodesk.com/support/revit-products/downloads site where i would expect to find UR's?
Many thanks,
Nick B
Message 24 of 30
Perfect, thanks Tony
Message 25 of 30
Hi Tony,
i dont suppose you have the DL links for Revit 2015 UR2 that has also been released? again it seems that its hitting App Managerbefore the knowledge sites again.
thanks in advance,
Nick B
Message 27 of 30
The confusing thing is that when you load it up in deployment it says Revit Architecture 2015 Version 3 (which throws you off, since it is UR2.) Ur1 said Version 2 thanks for posting these
Message 28 of 30
tony: So in my deployment should I have UR1 and UR2 files both in the deployment? or just the last one?
Message 29 of 30
Yeah, that is an odditiy that has been around for a while.  In this context, the original release of Revit is considered Version 1 so UR1 ends up being Version 2 and so on.
Also, Revit patches are cumulative so UR2 contains all of the updates from UR1.  For this reason, you only need to include the latest service pack when creating a deployment.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Revit Software QA Analyst
Message 30 of 30
renannpaes
My files can't be uploadeds in cloud, i tryed meny files and more than one user account. i just could render it at other machines, does any one konws something about my network or my OS that can be causing this problem?
thanks.
