Thanks for reading my post.
I am having problems to install the Revit Architecture 2014 through browser, as student.
The followings are the steps that I went through during the first attempt:
2014/2/7:22:47:44 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/7:22:47:44 Homayoun BARFI Path_Length: 149
2014/2/7:22:47:44 Homayoun BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/7:22:47:44 Homayoun BARFI Launch
2014/2/7:22:47:44 Homayoun BARFI CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44929069 /PK 829F1 /student /akamai /auth authparam /sid SESSION_ID
2014/2/7:22:47:44 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI6B3B.tmp
2014/2/7:22:49:55 Homayoun BARFI === Setup ended ===
2014/2/7:22:47:48 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/7:22:47:48 Homayoun BARFI Path_Length: 149
2014/2/7:22:47:48 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI6B3B.tmp
2014/2/7:22:47:48 Homayoun BARFI Launch
2014/2/7:22:49:05 Homayoun BARFI Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/7:22:49:53 Homayoun BARFI Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/7:22:49:53 Homayoun BARFI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Homayoun\AppData\Local\Temp\_AI6B3B.tmp\Setup\RevitSetup.dll
2014/2/7:22:49:53 Homayoun BARFI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/7:22:49:55 Homayoun BARFI PageOpen LaunchDialog
2014/2/7:22:57:04 Homayoun BARFI PageOpen LicenseDialog
2014/2/7:22:59:05 Homayoun BARFI PageOpen ProductInfoDialog
2014/2/7:22:59:06 Homayoun BARFI PageOpen ProductSelectionDialog2
2014/2/7:22:59:43 Homayoun BARFI PageOpen FullProgressDialog
2014/2/7:22:59:45 Homayoun BARFI Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:22:59:51 Homayoun BARFI Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:22:59:51 Homayoun BARFI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/2/7:23:00:24 Homayoun BARFI Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Succeeded
2014/2/7:23:00:24 Homayoun BARFI Download Play VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:00:27 Homayoun BARFI Download Complete VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:00:27 Homayoun BARFI Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/2/7:23:00:39 Homayoun BARFI Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/2/7:23:00:40 Homayoun BARFI Download Play VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:00:45 Homayoun BARFI Download Complete VCREDIST2005X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:00:45 Homayoun BARFI Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/7:23:00:56 Homayoun BARFI Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2014/2/7:23:00:56 Homayoun BARFI Download Play VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:01:02 Homayoun BARFI Download Complete VCREDIST2008SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:01:02 Homayoun BARFI Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/2/7:23:01:19 Homayoun BARFI Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2014/2/7:23:01:19 Homayoun BARFI Download Play VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:01:25 Homayoun BARFI Download Complete VCREDIST2010SP1X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:01:25 Homayoun BARFI Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/2/7:23:01:45 Homayoun BARFI Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2014/2/7:23:01:45 Homayoun BARFI Download Play VCREDIST2010SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:01:53 Homayoun BARFI Download Complete VCREDIST2010SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:01:53 Homayoun BARFI Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2014/2/7:23:02:08 Homayoun BARFI Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2014/2/7:23:02:08 Homayoun BARFI Download Play KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:02:09 Homayoun BARFI Download Complete KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:02:10 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:23:02:14 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/7:23:02:14 Homayoun BARFI Download Play KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:02:26 Homayoun BARFI Download Complete KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:02:26 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:23:03:08 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/7:23:03:09 Homayoun BARFI Download Play KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:03:15 Homayoun BARFI Download Complete KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:03:15 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:23:03:27 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/7:23:03:27 Homayoun BARFI Download Play KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:03:28 Homayoun BARFI Download Complete KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:03:28 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:23:03:39 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/7:23:03:39 Homayoun BARFI Download Play KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:03:40 Homayoun BARFI Download Complete KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:03:40 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:23:03:45 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/7:23:03:45 Homayoun BARFI Download Play KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:04:04 Homayoun BARFI Download Complete KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:04:04 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:23:04:16 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/7:23:04:16 Homayoun BARFI Download Play KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:04:20 Homayoun BARFI Download Complete KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:04:20 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:23:04:28 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/7:23:04:28 Homayoun BARFI Download Play KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:04:29 Homayoun BARFI Download Complete KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:04:29 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/7:23:04:36 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/7:23:04:36 Homayoun BARFI Download Play VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:04:49 Homayoun BARFI Download Complete VCREDIST2005SP1ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:04:49 Homayoun BARFI Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/2/7:23:05:16 Homayoun BARFI Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Succeeded
2014/2/7:23:05:16 Homayoun BARFI Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:05:25 Homayoun BARFI Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:05:25 Homayoun BARFI Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/7:23:05:54 Homayoun BARFI Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/2/7:23:05:55 Homayoun BARFI Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1619
2014/2/7:23:05:59 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/7:23:06:03 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/7:23:06:07 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/7:23:06:09 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/7:23:06:13 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/7:23:06:16 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/7:23:06:20 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/7:23:06:22 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/7:23:06:22 Homayoun BARFI Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2014/2/7:23:06:23 Homayoun BARFI Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
2014/2/7:23:06:23 Homayoun BARFI Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
2014/2/7:23:06:23 Homayoun BARFI Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2014/2/7:23:06:26 Homayoun BARFI PageOpen InstallCompleteDialog
2014/2/7:23:14:07 Homayoun BARFI === Setup ended ===
2014/2/8:14:32:24 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/8:14:32:24 Homayoun BARFI Path_Length: 149
2014/2/8:14:32:24 Homayoun BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/8:14:32:24 Homayoun BARFI Launch
2014/2/8:14:32:24 Homayoun BARFI CommandLine
2014/2/8:14:32:24 Homayoun BARFI Setup Windows update reboot is pending
2014/2/8:14:32:33 Homayoun BARFI === Setup ended ===
2014/2/8:14:40:20 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/8:14:40:20 Homayoun BARFI Path_Length: 149
2014/2/8:14:40:20 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIFC53.tmp
2014/2/8:14:40:20 Homayoun BARFI Launch
2014/2/8:14:40:27 Homayoun BARFI === Setup ended ===
2014/2/8:14:40:14 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/8:14:40:14 Homayoun BARFI Path_Length: 149
2014/2/8:14:40:14 Homayoun BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/8:14:40:14 Homayoun BARFI Launch
2014/2/8:14:40:14 Homayoun BARFI CommandLine
2014/2/8:14:40:14 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIFC53.tmp
2014/2/8:14:41:27 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/8:14:41:27 Homayoun BARFI Path_Length: 149
2014/2/8:14:41:27 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIDD2.tmp
2014/2/8:14:41:27 Homayoun BARFI Launch
2014/2/8:14:41:32 Homayoun BARFI === Setup ended ===
2014/2/8:14:42:28 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/8:14:42:28 Homayoun BARFI Path_Length: 149
2014/2/8:14:42:28 Homayoun BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/8:14:42:28 Homayoun BARFI Launch
2014/2/8:14:42:28 Homayoun BARFI CommandLine
2014/2/8:14:42:28 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI9B7.tmp
2014/2/8:14:42:48 Homayoun BARFI === Setup ended ===
2014/2/8:14:42:30 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/8:14:42:30 Homayoun BARFI Path_Length: 149
2014/2/8:14:42:30 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI9B7.tmp
2014/2/8:14:42:30 Homayoun BARFI Launch
2014/2/8:14:42:49 Homayoun BARFI === Setup ended ===
2014/2/8:15:04:27 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/8:15:04:27 Homayoun BARFI Path_Length: 149
2014/2/8:15:04:27 Homayoun BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/8:15:04:27 Homayoun BARFI Launch
2014/2/8:15:04:27 Homayoun BARFI CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/8:15:04:27 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI2878.tmp
2014/2/8:15:05:09 Homayoun BARFI === Setup ended ===
2014/2/8:15:04:31 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/8:15:04:31 Homayoun BARFI Path_Length: 149
2014/2/8:15:04:31 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI2878.tmp
2014/2/8:15:04:31 Homayoun BARFI Launch
2014/2/8:15:04:33 Homayoun BARFI Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/8:15:05:08 Homayoun BARFI Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/8:15:05:09 Homayoun BARFI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Homayoun\AppData\Local\Temp\_AI2878.tmp\Setup\RevitSetup.dll
2014/2/8:15:05:09 Homayoun BARFI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/8:15:05:10 Homayoun BARFI PageOpen LaunchDialog
2014/2/8:15:05:24 Homayoun BARFI PageOpen LicenseDialog
2014/2/8:15:05:34 Homayoun BARFI PageOpen ProductInfoDialog
2014/2/8:15:07:47 Homayoun BARFI PageOpen ProductSelectionDialog2
2014/2/8:15:09:26 Homayoun BARFI PageOpen FullProgressDialog
2014/2/8:15:09:27 Homayoun BARFI Download Play VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2014/2/8:15:09:29 Homayoun BARFI Download Complete VCREDIST2005X86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2014/2/8:15:09:29 Homayoun BARFI Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/2/8:15:09:44 Homayoun BARFI Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2014/2/8:15:09:45 Homayoun BARFI Download Play KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX...
2014/2/8:15:09:45 Homayoun BARFI Download Complete KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX...
2014/2/8:15:09:45 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/8:15:09:48 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/8:15:09:49 Homayoun BARFI Download Play KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX...
2014/2/8:15:09:53 Homayoun BARFI Download Complete KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX...
2014/2/8:15:09:53 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/8:15:10:02 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/8:15:10:03 Homayoun BARFI Download Play KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX...
2014/2/8:15:10:04 Homayoun BARFI Download Complete KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX...
2014/2/8:15:10:04 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/8:15:10:10 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/8:15:10:10 Homayoun BARFI Download Play KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN...
2014/2/8:15:10:10 Homayoun BARFI Download Complete KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN...
2014/2/8:15:10:10 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/8:15:10:16 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/8:15:10:16 Homayoun BARFI Download Play KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX...
2014/2/8:15:10:17 Homayoun BARFI Download Complete KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX...
2014/2/8:15:10:17 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/8:15:10:20 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/8:15:10:20 Homayoun BARFI Download Play KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX...
2014/2/8:15:10:25 Homayoun BARFI Download Complete KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX...
2014/2/8:15:10:25 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/8:15:10:33 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/8:15:10:33 Homayoun BARFI Download Play KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX...
2014/2/8:15:10:34 Homayoun BARFI Download Complete KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX...
2014/2/8:15:10:34 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/8:15:10:39 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/8:15:10:39 Homayoun BARFI Download Play KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN...
2014/2/8:15:10:40 Homayoun BARFI Download Complete KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN...
2014/2/8:15:10:40 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/8:15:10:44 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/8:15:10:44 Homayoun BARFI Download Play VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2014/2/8:15:10:46 Homayoun BARFI Download Complete VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2014/2/8:15:10:46 Homayoun BARFI Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/8:15:11:05 Homayoun BARFI Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1603
2014/2/8:15:11:08 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/8:15:11:11 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/8:15:11:14 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/8:15:11:16 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/8:15:11:19 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/8:15:11:22 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/8:15:11:25 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/8:15:11:27 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/8:15:11:27 Homayoun BARFI Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
So I tried again:
2014/2/9:01:15:09 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:01:15:09 Homayoun BARFI Path_Length: 149
2014/2/9:01:15:09 Homayoun BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/9:01:15:09 Homayoun BARFI Launch
2014/2/9:01:15:09 Homayoun BARFI CommandLine
2014/2/9:01:15:09 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI4F1C.tmp
2014/2/9:01:15:18 Homayoun BARFI === Setup ended ===
2014/2/9:01:15:12 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:01:15:12 Homayoun BARFI Path_Length: 149
2014/2/9:01:15:12 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI4F1C.tmp
2014/2/9:01:15:12 Homayoun BARFI Launch
2014/2/9:01:15:19 Homayoun BARFI === Setup ended ===
2014/2/9:13:40:04 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:13:40:04 Homayoun BARFI Path_Length: 149
2014/2/9:13:40:04 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI28B3.tmp
2014/2/9:13:40:04 Homayoun BARFI Launch
2014/2/9:13:40:07 Homayoun BARFI === Setup ended ===
2014/2/9:13:39:55 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:13:39:55 Homayoun BARFI Path_Length: 149
2014/2/9:13:39:55 Homayoun BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/9:13:39:55 Homayoun BARFI Launch
2014/2/9:13:39:55 Homayoun BARFI CommandLine
2014/2/9:13:39:55 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI28B3.tmp
2014/2/9:16:43:59 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:16:43:59 Homayoun BARFI Path_Length: 149
2014/2/9:16:43:59 Homayoun BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/9:16:43:59 Homayoun BARFI Launch
2014/2/9:16:43:59 Homayoun BARFI CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/9:16:43:59 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIDB37.tmp
2014/2/9:16:44:07 Homayoun BARFI === Setup ended ===
2014/2/9:16:44:02 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:16:44:02 Homayoun BARFI Path_Length: 149
2014/2/9:16:44:02 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIDB37.tmp
2014/2/9:16:44:02 Homayoun BARFI Launch
2014/2/9:16:44:04 Homayoun BARFI Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/9:16:44:05 Homayoun BARFI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Homayoun\AppData\Local\Temp\_AIDB37.tmp\Setup\RevitSetup.dll
2014/2/9:16:44:05 Homayoun BARFI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/9:16:44:06 Homayoun BARFI PageOpen LaunchDialog
2014/2/9:16:44:18 Homayoun BARFI PageOpen LicenseDialog
2014/2/9:16:44:24 Homayoun BARFI PageOpen ProductSelectionDialog2
2014/2/9:16:45:04 Homayoun BARFI PageOpen FullProgressDialog
2014/2/9:16:45:04 Homayoun BARFI Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/9:16:45:08 Homayoun BARFI Install Network License Manager Succeeded
2014/2/9:16:45:10 Homayoun BARFI Download Play CADM http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CADM_x64_en-...
2014/2/9:16:45:14 Homayoun BARFI Download Complete CADM http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CADM_x64_en-...
2014/2/9:16:45:14 Homayoun BARFI Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/9:16:45:16 Homayoun BARFI Install Autodesk CAD Manager Tools Succeeded
2014/2/9:16:45:16 Homayoun BARFI PageOpen InstallCompleteDialog
2014/2/9:16:45:23 Homayoun BARFI === Setup ended ===
2014/2/9:16:49:33 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:16:49:33 Homayoun BARFI Path_Length: 149
2014/2/9:16:49:33 Homayoun BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/9:16:49:33 Homayoun BARFI Launch
2014/2/9:16:49:33 Homayoun BARFI CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/9:16:49:33 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIF4C2.tmp
2014/2/9:16:49:41 Homayoun BARFI === Setup ended ===
2014/2/9:16:49:37 Homayoun BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:16:49:37 Homayoun BARFI Path_Length: 149
2014/2/9:16:49:37 Homayoun BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIF4C2.tmp
2014/2/9:16:49:37 Homayoun BARFI Launch
2014/2/9:16:49:38 Homayoun BARFI Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/9:16:49:38 Homayoun BARFI Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Homayoun\AppData\Local\Temp\_AIF4C2.tmp\Setup\RevitSetup.dll
2014/2/9:16:49:38 Homayoun BARFI Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/9:16:49:39 Homayoun BARFI PageOpen LaunchDialog
2014/2/9:16:49:48 Homayoun BARFI PageOpen LicenseDialog
2014/2/9:16:49:55 Homayoun BARFI PageOpen ProductInfoDialog
2014/2/9:16:52:14 Homayoun BARFI PageOpen ProductSelectionDialog2
2014/2/9:16:52:42 Homayoun BARFI PageOpen FullProgressDialog
2014/2/9:16:52:43 Homayoun BARFI Download Skipped KB958314ATLX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX...
2014/2/9:16:52:43 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/9:16:52:48 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2014/2/9:16:52:48 Homayoun BARFI Download Skipped KB958314MFCX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX...
2014/2/9:16:52:48 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/9:16:52:57 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/9:16:52:57 Homayoun BARFI Download Skipped KB958314CRTX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX...
2014/2/9:16:52:57 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/9:16:53:04 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/9:16:53:04 Homayoun BARFI Download Skipped KB958314OPENMPX86 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN...
2014/2/9:16:53:04 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/9:16:53:09 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/9:16:53:09 Homayoun BARFI Download Skipped KB958314ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX...
2014/2/9:16:53:09 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/9:16:53:12 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/9:16:53:12 Homayoun BARFI Download Skipped KB958314MFCX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX...
2014/2/9:16:53:12 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/9:16:53:20 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/9:16:53:20 Homayoun BARFI Download Skipped KB958314CRTX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX...
2014/2/9:16:53:20 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/9:16:53:26 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/9:16:53:26 Homayoun BARFI Download Skipped KB958314OPENMPX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN...
2014/2/9:16:53:26 Homayoun BARFI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/9:16:53:32 Homayoun BARFI Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/9:16:53:32 Homayoun BARFI Download Skipped VCREDIST2005SP1ATLX64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2014/2/9:16:53:32 Homayoun BARFI Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/9:16:53:52 Homayoun BARFI Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Succeeded
2014/2/9:16:53:53 Homayoun BARFI Download Play DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/9:16:53:57 Homayoun BARFI Download Complete DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/9:16:53:57 Homayoun BARFI Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/9:16:55:00 Homayoun BARFI Install DirectX® Runtime Succeeded
2014/2/9:16:55:01 Homayoun BARFI Download Play FaroSDK http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/FaroSDK_x64....
2014/2/9:16:55:07 Homayoun BARFI Download Complete FaroSDK http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/FaroSDK_x64....
2014/2/9:16:55:07 Homayoun BARFI Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/2/9:16:55:36 Homayoun BARFI Install FaroSDK Succeeded
2014/2/9:16:55:37 Homayoun BARFI Download Play RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/9:17:04:40 Homayoun BARFI Download Aborted RVT2014 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/9:17:04:40 Homayoun BARFI Install Autodesk® Revit® 2014 Failed Download Failed, Installation aborted, Result=1603
2014/2/9:17:05:10 Homayoun BARFI Rollback FaroSDK Succeeded
2014/2/9:17:05:10 Homayoun BARFI Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2014/2/9:17:05:10 Homayoun BARFI Rollback Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64) Failed Installation aborted, Result=1619
2014/2/9:17:05:15 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2014/2/9:17:05:20 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2014/2/9:17:05:25 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2014/2/9:17:05:28 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2014/2/9:17:05:34 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2014/2/9:17:05:41 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2014/2/9:17:05:46 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2014/2/9:17:05:49 Homayoun BARFI Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
On this forum I have found this posting:
Error 1603 and 1619 when installing Revit 2014?
But the links to ASK do not connect.
Could you please help to point the problem and to install?
Hello MoziBah,
Error in the log is about Installing Microsoft Visual C++ 2005 SP1 Redistributable.
Please refer below link for information to help you to resolve your issues:
Hope this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Hello MoziBah,
I’m sorry that Revit 2014 is not officially supported for Windows 8.1 at present. So I'm not sure if it applies to your case.
Here’s a post about AutoCAD 2014 and Windows 8.1.
Please find additional information in our blog: Windows 8.1 Support = Please upgrade cautiously!
