Revit Architecture 2014 installation fails, errors 1619 and 1603
3 REPLIES 3
MoziBah
509 Views, 3 Replies
Thanks for reading my post.
I am having problems to install the Revit Architecture 2014 through browser, as student.
The followings are the steps that I went through during the first attempt:
  • Installed updates
  • Tried to install Revit, Failed and the following is the installation log:
2014/2/7:22:47:44    Homayoun    BARFI    === Setup started on BARFI by Homayoun ===
2014/2/7:22:47:44    Homayoun    BARFI    Path_Length: 149
2014/2/7:22:47:44    Homayoun    BARFI    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/7:22:47:44    Homayoun    BARFI    Launch
2014/2/7:22:47:44    Homayoun    BARFI    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-... /SN 900-44929069 /PK 829F1 /student  /akamai /auth authparam /sid SESSION_ID
2014/2/7:22:47:44    Homayoun    BARFI    Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI6B3B.tmp
2014/2/7:22:49:55    Homayoun    BARFI    === Setup ended ===
2014/2/7:22:47:48    Homayoun    BARFI    === Setup started on BARFI by Homayoun ===
2014/2/7:22:47:48    Homayoun    BARFI    Path_Length: 149
2014/2/7:22:47:48    Homayoun    BARFI    Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI6B3B.tmp
2014/2/7:22:47:48    Homayoun    BARFI    Launch
2014/2/7:22:49:05    Homayoun    BARFI    Download    Play    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/7:22:49:53    Homayoun    BARFI    Download    Complete    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/SETUP_x6...
2014/2/7:22:49:53    Homayoun    BARFI    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Homayoun\AppData\Local\Temp\_AI6B3B.tmp\Setup\RevitSetup.dll
2014/2/7:22:49:53    Homayoun    BARFI    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/7:22:49:55    Homayoun    BARFI    PageOpen    LaunchDialog
2014/2/7:22:57:04    Homayoun    BARFI    PageOpen    LicenseDialog
2014/2/7:22:59:05    Homayoun    BARFI    PageOpen    ProductInfoDialog
2014/2/7:22:59:06    Homayoun    BARFI    PageOpen    ProductSelectionDialog2
2014/2/7:22:59:43    Homayoun    BARFI    PageOpen    FullProgressDialog
2014/2/7:22:59:45    Homayoun    BARFI    Download    Play    VCREDIST2008SP1X64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:22:59:51    Homayoun    BARFI    Download    Complete    VCREDIST2008SP1X64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:22:59:51    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2014/2/7:23:00:24    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x64)    Succeeded
2014/2/7:23:00:24    Homayoun    BARFI    Download    Play    VCREDIST2005X86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:00:27    Homayoun    BARFI    Download    Complete    VCREDIST2005X86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:00:27    Homayoun    BARFI    Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/2/7:23:00:39    Homayoun    BARFI    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Succeeded
2014/2/7:23:00:40    Homayoun    BARFI    Download    Play    VCREDIST2005X64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:00:45    Homayoun    BARFI    Download    Complete    VCREDIST2005X64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:00:45    Homayoun    BARFI    Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/7:23:00:56    Homayoun    BARFI    Install    Microsoft Visual C++ 2005 Redistributable (x64)    Succeeded
2014/2/7:23:00:56    Homayoun    BARFI    Download    Play    VCREDIST2008SP1X86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:01:02    Homayoun    BARFI    Download    Complete    VCREDIST2008SP1X86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:01:02    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe" /q
2014/2/7:23:01:19    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 SP1 Redistributable (x86)    Succeeded
2014/2/7:23:01:19    Homayoun    BARFI    Download    Play    VCREDIST2010SP1X86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:01:25    Homayoun    BARFI    Download    Complete    VCREDIST2010SP1X86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:01:25    Homayoun    BARFI    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe" /q /norestart
2014/2/7:23:01:45    Homayoun    BARFI    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Succeeded
2014/2/7:23:01:45    Homayoun    BARFI    Download    Play    VCREDIST2010SP1X64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:01:53    Homayoun    BARFI    Download    Complete    VCREDIST2010SP1X64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:01:53    Homayoun    BARFI    Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe" /q /norestart
2014/2/7:23:02:08    Homayoun    BARFI    Install    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Succeeded
2014/2/7:23:02:08    Homayoun    BARFI    Download    Play    KB958314ATLX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:02:09    Homayoun    BARFI    Download    Complete    KB958314ATLX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:02:10    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:23:02:14    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x86)    Succeeded
2014/2/7:23:02:14    Homayoun    BARFI    Download    Play    KB958314MFCX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:02:26    Homayoun    BARFI    Download    Complete    KB958314MFCX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:02:26    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:23:03:08    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x86)    Succeeded
2014/2/7:23:03:09    Homayoun    BARFI    Download    Play    KB958314CRTX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:03:15    Homayoun    BARFI    Download    Complete    KB958314CRTX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:03:15    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:23:03:27    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x86)    Succeeded
2014/2/7:23:03:27    Homayoun    BARFI    Download    Play    KB958314OPENMPX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:03:28    Homayoun    BARFI    Download    Complete    KB958314OPENMPX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:03:28    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:23:03:39    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)    Succeeded
2014/2/7:23:03:39    Homayoun    BARFI    Download    Play    KB958314ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:03:40    Homayoun    BARFI    Download    Complete    KB958314ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:03:40    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:23:03:45    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
2014/2/7:23:03:45    Homayoun    BARFI    Download    Play    KB958314MFCX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:04:04    Homayoun    BARFI    Download    Complete    KB958314MFCX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:04:04    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:23:04:16    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
2014/2/7:23:04:16    Homayoun    BARFI    Download    Play    KB958314CRTX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:04:20    Homayoun    BARFI    Download    Complete    KB958314CRTX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:04:20    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:23:04:28    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
2014/2/7:23:04:28    Homayoun    BARFI    Download    Play    KB958314OPENMPX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:04:29    Homayoun    BARFI    Download    Complete    KB958314OPENMPX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/KB958314...
2014/2/7:23:04:29    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/7:23:04:36    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
2014/2/7:23:04:36    Homayoun    BARFI    Download    Play    VCREDIST2005SP1ATLX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:04:49    Homayoun    BARFI    Download    Complete    VCREDIST2005SP1ATLX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:04:49    Homayoun    BARFI    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/2/7:23:05:16    Homayoun    BARFI    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Succeeded
2014/2/7:23:05:16    Homayoun    BARFI    Download    Play    VCREDIST2005SP1ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:05:25    Homayoun    BARFI    Download    Complete    VCREDIST2005SP1ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E}/VCREDIST...
2014/2/7:23:05:25    Homayoun    BARFI    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/7:23:05:54    Homayoun    BARFI    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/2/7:23:05:55    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)    Failed    Installation aborted, Result=1619
2014/2/7:23:05:59    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
2014/2/7:23:06:03    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
2014/2/7:23:06:07    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
2014/2/7:23:06:09    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
2014/2/7:23:06:13    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)    Succeeded
2014/2/7:23:06:16    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x86)    Succeeded
2014/2/7:23:06:20    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x86)    Succeeded
2014/2/7:23:06:22    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x86)    Succeeded
2014/2/7:23:06:22    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x64)    Failed    Installation aborted, Result=1619
2014/2/7:23:06:23    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2010 SP1 Redistributable (x86)    Failed    Installation aborted, Result=1619
2014/2/7:23:06:23    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2005 Redistributable (x64)    Failed    Installation aborted, Result=1619
2014/2/7:23:06:23    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1619
2014/2/7:23:06:26    Homayoun    BARFI    PageOpen    InstallCompleteDialog
2014/2/7:23:14:07    Homayoun    BARFI    === Setup ended ===
2014/2/8:14:32:24    Homayoun    BARFI    === Setup started on BARFI by Homayoun ===
2014/2/8:14:32:24    Homayoun    BARFI    Path_Length: 149
2014/2/8:14:32:24    Homayoun    BARFI    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/8:14:32:24    Homayoun    BARFI    Launch
2014/2/8:14:32:24    Homayoun    BARFI    CommandLine
2014/2/8:14:32:24    Homayoun    BARFI    Setup    Windows update reboot is pending
2014/2/8:14:32:33    Homayoun    BARFI    === Setup ended ===
2014/2/8:14:40:20    Homayoun    BARFI    === Setup started on BARFI by Homayoun ===
2014/2/8:14:40:20    Homayoun    BARFI    Path_Length: 149
2014/2/8:14:40:20    Homayoun    BARFI    Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIFC53.tmp
2014/2/8:14:40:20    Homayoun    BARFI    Launch
2014/2/8:14:40:27    Homayoun    BARFI    === Setup ended ===
2014/2/8:14:40:14    Homayoun    BARFI    === Setup started on BARFI by Homayoun ===
2014/2/8:14:40:14    Homayoun    BARFI    Path_Length: 149
2014/2/8:14:40:14    Homayoun    BARFI    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/8:14:40:14    Homayoun    BARFI    Launch
2014/2/8:14:40:14    Homayoun    BARFI    CommandLine
2014/2/8:14:40:14    Homayoun    BARFI    Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIFC53.tmp
2014/2/8:14:41:27    Homayoun    BARFI    === Setup started on BARFI by Homayoun ===
2014/2/8:14:41:27    Homayoun    BARFI    Path_Length: 149
2014/2/8:14:41:27    Homayoun    BARFI    Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIDD2.tmp
2014/2/8:14:41:27    Homayoun    BARFI    Launch
2014/2/8:14:41:32    Homayoun    BARFI    === Setup ended ===
2014/2/8:14:42:28    Homayoun    BARFI    === Setup started on BARFI by Homayoun ===
2014/2/8:14:42:28    Homayoun    BARFI    Path_Length: 149
2014/2/8:14:42:28    Homayoun    BARFI    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/8:14:42:28    Homayoun    BARFI    Launch
2014/2/8:14:42:28    Homayoun    BARFI    CommandLine
2014/2/8:14:42:28    Homayoun    BARFI    Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI9B7.tmp
2014/2/8:14:42:48    Homayoun    BARFI    === Setup ended ===
2014/2/8:14:42:30    Homayoun    BARFI    === Setup started on BARFI by Homayoun ===
2014/2/8:14:42:30    Homayoun    BARFI    Path_Length: 149
2014/2/8:14:42:30    Homayoun    BARFI    Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI9B7.tmp
2014/2/8:14:42:30    Homayoun    BARFI    Launch
2014/2/8:14:42:49    Homayoun    BARFI    === Setup ended ===
2014/2/8:15:04:27    Homayoun    BARFI    === Setup started on BARFI by Homayoun ===
2014/2/8:15:04:27    Homayoun    BARFI    Path_Length: 149
2014/2/8:15:04:27    Homayoun    BARFI    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/8:15:04:27    Homayoun    BARFI    Launch
2014/2/8:15:04:27    Homayoun    BARFI    CommandLine    /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/8:15:04:27    Homayoun    BARFI    Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI2878.tmp
2014/2/8:15:05:09    Homayoun    BARFI    === Setup ended ===
2014/2/8:15:04:31    Homayoun    BARFI    === Setup started on BARFI by Homayoun ===
2014/2/8:15:04:31    Homayoun    BARFI    Path_Length: 149
2014/2/8:15:04:31    Homayoun    BARFI    Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI2878.tmp
2014/2/8:15:04:31    Homayoun    BARFI    Launch
2014/2/8:15:04:33    Homayoun    BARFI    Download    Play    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/8:15:05:08    Homayoun    BARFI    Download    Complete    SETUP_CONFIG    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/8:15:05:09    Homayoun    BARFI    Install    CustomCallback    Info    Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Homayoun\AppData\Local\Temp\_AI2878.tmp\Setup\RevitSetup.dll
2014/2/8:15:05:09    Homayoun    BARFI    Install    CustomCallback    Info    Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/8:15:05:10    Homayoun    BARFI    PageOpen    LaunchDialog
2014/2/8:15:05:24    Homayoun    BARFI    PageOpen    LicenseDialog
2014/2/8:15:05:34    Homayoun    BARFI    PageOpen    ProductInfoDialog
2014/2/8:15:07:47    Homayoun    BARFI    PageOpen    ProductSelectionDialog2
2014/2/8:15:09:26    Homayoun    BARFI    PageOpen    FullProgressDialog
2014/2/8:15:09:27    Homayoun    BARFI    Download    Play    VCREDIST2005X86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2014/2/8:15:09:29    Homayoun    BARFI    Download    Complete    VCREDIST2005X86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2014/2/8:15:09:29    Homayoun    BARFI    Installing Microsoft Visual C++ 2005 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x86\VCRedist\2005\vcredist_x86.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/2/8:15:09:44    Homayoun    BARFI    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Succeeded
2014/2/8:15:09:45    Homayoun    BARFI    Download    Play    KB958314ATLX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX...
2014/2/8:15:09:45    Homayoun    BARFI    Download    Complete    KB958314ATLX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX...
2014/2/8:15:09:45    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/8:15:09:48    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x86)    Succeeded
2014/2/8:15:09:49    Homayoun    BARFI    Download    Play    KB958314MFCX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX...
2014/2/8:15:09:53    Homayoun    BARFI    Download    Complete    KB958314MFCX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX...
2014/2/8:15:09:53    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/8:15:10:02    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x86)    Succeeded
2014/2/8:15:10:03    Homayoun    BARFI    Download    Play    KB958314CRTX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX...
2014/2/8:15:10:04    Homayoun    BARFI    Download    Complete    KB958314CRTX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX...
2014/2/8:15:10:04    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/8:15:10:10    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x86)    Succeeded
2014/2/8:15:10:10    Homayoun    BARFI    Download    Play    KB958314OPENMPX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN...
2014/2/8:15:10:10    Homayoun    BARFI    Download    Complete    KB958314OPENMPX86    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN...
2014/2/8:15:10:10    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/8:15:10:16    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)    Succeeded
2014/2/8:15:10:16    Homayoun    BARFI    Download    Play    KB958314ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX...
2014/2/8:15:10:17    Homayoun    BARFI    Download    Complete    KB958314ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX...
2014/2/8:15:10:17    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/8:15:10:20    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
2014/2/8:15:10:20    Homayoun    BARFI    Download    Play    KB958314MFCX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX...
2014/2/8:15:10:25    Homayoun    BARFI    Download    Complete    KB958314MFCX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX...
2014/2/8:15:10:25    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/8:15:10:33    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
2014/2/8:15:10:33    Homayoun    BARFI    Download    Play    KB958314CRTX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX...
2014/2/8:15:10:34    Homayoun    BARFI    Download    Complete    KB958314CRTX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX...
2014/2/8:15:10:34    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/8:15:10:39    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
2014/2/8:15:10:39    Homayoun    BARFI    Download    Play    KB958314OPENMPX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN...
2014/2/8:15:10:40    Homayoun    BARFI    Download    Complete    KB958314OPENMPX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN...
2014/2/8:15:10:40    Homayoun    BARFI    Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/8:15:10:44    Homayoun    BARFI    Install    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
2014/2/8:15:10:44    Homayoun    BARFI    Download    Play    VCREDIST2005SP1ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2014/2/8:15:10:46    Homayoun    BARFI    Download    Complete    VCREDIST2005SP1ATLX64    http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2014/2/8:15:10:46    Homayoun    BARFI    Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/8:15:11:05    Homayoun    BARFI    Install    Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)    Failed    Installation aborted, Result=1603
2014/2/8:15:11:08    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)    Succeeded
2014/2/8:15:11:11    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x64)    Succeeded
2014/2/8:15:11:14    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x64)    Succeeded
2014/2/8:15:11:16    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x64)    Succeeded
2014/2/8:15:11:19    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)    Succeeded
2014/2/8:15:11:22    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (CRT) (x86)    Succeeded
2014/2/8:15:11:25    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (MFC) (x86)    Succeeded
2014/2/8:15:11:27    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2008 KB958314 (ATL) (x86)    Succeeded
2014/2/8:15:11:27    Homayoun    BARFI    Rollback    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1619
So I tried again:
  • Emptied the TEMP
  • Installed C++2008, successfully
  • Disabled UAC
  • Disabled Antivirus
  • Tried it install again, Failed and this is the latest installation log:
2014/2/9:01:15:09       Homayoun      BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:01:15:09       Homayoun      BARFI Path_Length: 149
2014/2/9:01:15:09       Homayoun      BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/9:01:15:09       Homayoun      BARFI Launch
2014/2/9:01:15:09       Homayoun      BARFI CommandLine
2014/2/9:01:15:09       Homayoun      BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI4F1C.tmp
2014/2/9:01:15:18       Homayoun      BARFI === Setup ended ===
2014/2/9:01:15:12       Homayoun      BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:01:15:12       Homayoun      BARFI Path_Length: 149
2014/2/9:01:15:12       Homayoun      BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI4F1C.tmp
2014/2/9:01:15:12       Homayoun      BARFI Launch
2014/2/9:01:15:19       Homayoun      BARFI === Setup ended ===
2014/2/9:13:40:04       Homayoun      BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:13:40:04       Homayoun      BARFI Path_Length: 149
2014/2/9:13:40:04       Homayoun      BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI28B3.tmp
2014/2/9:13:40:04       Homayoun      BARFI Launch
2014/2/9:13:40:07       Homayoun      BARFI === Setup ended ===
2014/2/9:13:39:55       Homayoun      BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:13:39:55       Homayoun      BARFI Path_Length: 149
2014/2/9:13:39:55       Homayoun      BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/9:13:39:55       Homayoun      BARFI Launch
2014/2/9:13:39:55       Homayoun      BARFI CommandLine
2014/2/9:13:39:55       Homayoun      BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AI28B3.tmp
2014/2/9:16:43:59       Homayoun      BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:16:43:59       Homayoun      BARFI Path_Length: 149
2014/2/9:16:43:59       Homayoun      BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/9:16:43:59       Homayoun      BARFI Launch
2014/2/9:16:43:59       Homayoun      BARFI CommandLine            /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/9:16:43:59       Homayoun      BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIDB37.tmp
2014/2/9:16:44:07       Homayoun      BARFI === Setup ended ===
2014/2/9:16:44:02       Homayoun      BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:16:44:02       Homayoun      BARFI Path_Length: 149
2014/2/9:16:44:02       Homayoun      BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIDB37.tmp
2014/2/9:16:44:02       Homayoun      BARFI Launch
2014/2/9:16:44:04       Homayoun      BARFI Download        Skipped           SETUP_CONFIG            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/9:16:44:05       Homayoun      BARFI Install   CustomCallback         Info      Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Homayoun\AppData\Local\Temp\_AIDB37.tmp\Setup\RevitSetup.dll
2014/2/9:16:44:05       Homayoun      BARFI Install   CustomCallback         Info      Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/9:16:44:06       Homayoun      BARFI PageOpen       LaunchDialog
2014/2/9:16:44:18       Homayoun      BARFI PageOpen       LicenseDialog
2014/2/9:16:44:24       Homayoun      BARFI PageOpen       ProductSelectionDialog2
2014/2/9:16:45:04       Homayoun      BARFI PageOpen       FullProgressDialog
2014/2/9:16:45:04       Homayoun      BARFI Installing Network License Manager:  ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\"  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk Network License Manager\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/9:16:45:08      Homayoun      BARFI Install   Network License Manager     Succeeded
2014/2/9:16:45:10       Homayoun      BARFI Download        Play     CADM            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CADM_x64_en-...
2014/2/9:16:45:14       Homayoun      BARFI Download        Complete        CADM            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/CADM_x64_en-...
2014/2/9:16:45:14       Homayoun      BARFI Installing Autodesk CAD Manager Tools:   INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\"  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="SSE2 Support Check,;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/9:16:45:16      Homayoun      BARFI Install   Autodesk CAD Manager Tools           Succeeded
2014/2/9:16:45:16       Homayoun      BARFI PageOpen       InstallCompleteDialog
2014/2/9:16:45:23       Homayoun      BARFI === Setup ended ===
2014/2/9:16:49:33       Homayoun      BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:16:49:33       Homayoun      BARFI Path_Length: 149
2014/2/9:16:49:33       Homayoun      BARFI Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2014/2/9:16:49:33       Homayoun      BARFI Launch
2014/2/9:16:49:33       Homayoun      BARFI CommandLine            /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S... /akamai /auth authparam /sid SESSION_ID
2014/2/9:16:49:33       Homayoun      BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIF4C2.tmp
2014/2/9:16:49:41       Homayoun      BARFI === Setup ended ===
2014/2/9:16:49:37       Homayoun      BARFI === Setup started on BARFI by Homayoun ===
2014/2/9:16:49:37       Homayoun      BARFI Path_Length: 149
2014/2/9:16:49:37       Homayoun      BARFI Current Directory C:\Users\Homayoun\AppData\Local\Temp\_AIF4C2.tmp
2014/2/9:16:49:37       Homayoun      BARFI Launch
2014/2/9:16:49:38       Homayoun      BARFI Download        Skipped           SETUP_CONFIG            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2014/2/9:16:49:38       Homayoun      BARFI Install   CustomCallback         Info      Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Homayoun\AppData\Local\Temp\_AIF4C2.tmp\Setup\RevitSetup.dll
2014/2/9:16:49:38       Homayoun      BARFI Install   CustomCallback         Info      Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2014/2/9:16:49:39       Homayoun      BARFI PageOpen       LaunchDialog
2014/2/9:16:49:48       Homayoun      BARFI PageOpen       LicenseDialog
2014/2/9:16:49:55       Homayoun      BARFI PageOpen       ProductInfoDialog
2014/2/9:16:52:14       Homayoun      BARFI PageOpen       ProductSelectionDialog2
2014/2/9:16:52:42       Homayoun      BARFI PageOpen       FullProgressDialog
2014/2/9:16:52:43       Homayoun      BARFI Download        Skipped           KB958314ATLX86            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX...
2014/2/9:16:52:43       Homayoun      BARFI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/9:16:52:48      Homayoun      BARFI Install   Microsoft Visual C++ 2008 KB958314 (ATL) (x86)   Succeeded
2014/2/9:16:52:48       Homayoun      BARFI Download        Skipped           KB958314MFCX86            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX...
2014/2/9:16:52:48       Homayoun      BARFI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/9:16:52:57      Homayoun      BARFI Install   Microsoft Visual C++ 2008 KB958314 (MFC) (x86)  Succeeded
2014/2/9:16:52:57       Homayoun      BARFI Download        Skipped           KB958314CRTX86            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX...
2014/2/9:16:52:57       Homayoun      BARFI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/9:16:53:04      Homayoun      BARFI Install   Microsoft Visual C++ 2008 KB958314 (CRT) (x86)  Succeeded
2014/2/9:16:53:04       Homayoun      BARFI Download        Skipped           KB958314OPENMPX86            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN...
2014/2/9:16:53:04       Homayoun      BARFI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/9:16:53:09      Homayoun      BARFI Install   Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)            Succeeded
2014/2/9:16:53:09       Homayoun      BARFI Download        Skipped           KB958314ATLX64            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314ATLX...
2014/2/9:16:53:09       Homayoun      BARFI Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/9:16:53:12      Homayoun      BARFI Install   Microsoft Visual C++ 2008 KB958314 (ATL) (x64)   Succeeded
2014/2/9:16:53:12       Homayoun      BARFI Download        Skipped           KB958314MFCX64            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314MFCX...
2014/2/9:16:53:12       Homayoun      BARFI Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/9:16:53:20      Homayoun      BARFI Install   Microsoft Visual C++ 2008 KB958314 (MFC) (x64)  Succeeded
2014/2/9:16:53:20       Homayoun      BARFI Download        Skipped           KB958314CRTX64            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314CRTX...
2014/2/9:16:53:20       Homayoun      BARFI Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/9:16:53:26      Homayoun      BARFI Install   Microsoft Visual C++ 2008 KB958314 (CRT) (x64)  Succeeded
2014/2/9:16:53:26       Homayoun      BARFI Download        Skipped           KB958314OPENMPX64            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/KB958314OPEN...
2014/2/9:16:53:26       Homayoun      BARFI Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64):   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/9:16:53:32      Homayoun      BARFI Install   Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)            Succeeded
2014/2/9:16:53:32       Homayoun      BARFI Download        Skipped           VCREDIST2005SP1ATLX64            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2005...
2014/2/9:16:53:32       Homayoun      BARFI Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\WINDOWS\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Homayoun\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/2/9:16:53:52       Homayoun      BARFI Install   Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)   Succeeded
2014/2/9:16:53:53       Homayoun      BARFI Download        Play     DIRECTX            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/9:16:53:57       Homayoun      BARFI Download        Complete        DIRECTX            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/DIRECTX.tar....
2014/2/9:16:53:57       Homayoun      BARFI Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/2/9:16:55:00       Homayoun      BARFI Install   DirectX® Runtime      Succeeded
2014/2/9:16:55:01       Homayoun      BARFI Download        Play     FaroSDK            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/FaroSDK_x64....
2014/2/9:16:55:07       Homayoun      BARFI Download        Complete        FaroSDK            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/FaroSDK_x64....
2014/2/9:16:55:07       Homayoun      BARFI Installing FaroSDK:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/2/9:16:55:36      Homayoun      BARFI Install   FaroSDK         Succeeded
2014/2/9:16:55:37       Homayoun      BARFI Download        Play     RVT2014            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/9:17:04:40       Homayoun      BARFI Download        Aborted           RVT2014            http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/RVT2014_x64....
2014/2/9:17:04:40       Homayoun      BARFI Install   Autodesk® Revit® 2014         Failed  Download Failed, Installation aborted, Result=1603
2014/2/9:17:05:10       Homayoun      BARFI Rollback          FaroSDK         Succeeded
2014/2/9:17:05:10       Homayoun      BARFI Rollback          DirectX® Runtime      Failed  Failure is ignored, Result=1619
2014/2/9:17:05:10       Homayoun      BARFI Rollback          Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x64)            Failed  Installation aborted, Result=1619
2014/2/9:17:05:15       Homayoun      BARFI Rollback          Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64)            Succeeded
2014/2/9:17:05:20       Homayoun      BARFI Rollback          Microsoft Visual C++ 2008 KB958314 (CRT) (x64)            Succeeded
2014/2/9:17:05:25       Homayoun      BARFI Rollback          Microsoft Visual C++ 2008 KB958314 (MFC) (x64)            Succeeded
2014/2/9:17:05:28       Homayoun      BARFI Rollback          Microsoft Visual C++ 2008 KB958314 (ATL) (x64)            Succeeded
2014/2/9:17:05:34       Homayoun      BARFI Rollback          Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86)            Succeeded
2014/2/9:17:05:41       Homayoun      BARFI Rollback          Microsoft Visual C++ 2008 KB958314 (CRT) (x86)            Succeeded
2014/2/9:17:05:46       Homayoun      BARFI Rollback          Microsoft Visual C++ 2008 KB958314 (MFC) (x86)            Succeeded
2014/2/9:17:05:49       Homayoun      BARFI Rollback          Microsoft Visual C++ 2008 KB958314 (ATL) (x86)            Succeeded
On this forum I have found this posting:
Error 1603 and 1619 when installing Revit 2014?
At :   http://forums.autodesk.com/t5/Installation-Licensing/Error-1603-and-1619-when-installing-Revit-2014/...
But the links to ASK do not connect.
Could you please help to point the problem and to install?
3 REPLIES 3
luna.ye
in reply to: MoziBah
Hello MoziBah,
Error in the log is about Installing Microsoft Visual C++ 2005 SP1 Redistributable.
Please refer below link for information to help you to resolve your issues:
http://forums.autodesk.com/t5/Installation-Licensing/Error-1603-and-1619-during-Revit-2012-installat...
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-1...
Hope this helps.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Luna Ye
Product Support
MoziBah
in reply to: luna.ye
Thanks Luna,
I am using Windows 8.1, I wonder if that information applies to my case?!
Thanks for your feed back
luna.ye
Hello MoziBah,
I’m sorry that Revit 2014 is not officially supported for Windows 8.1 at present. So I'm not sure if it applies to your case.
Here’s a post about AutoCAD 2014 and Windows 8.1.
Please find additional information in our blog:  Windows 8.1 Support = Please upgrade cautiously!
Luna Ye
Product Support
