Revit Architecture 2013 update release 3 will not install
3 REPLIES 3
yilin
923 Views, 3 Replies
I need to install the update for my Revit 2013, however when I try, it gives me the following error message below.
My coworker was able to install the update without any issues.  She has her Revit 2013 on her C Drive, but I have mine on an alternate D drive (my C Drive was full).
Do you know if that is the problem? That the update can't find my Revit b/c it is not on the default drive?  What can I do to solve this problem?
3 REPLIES 3
DarrenP
in reply to: yilin
because thats the wrong update
if your running revit architecture you need to install this update
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21890399&linkID=21208796
DarrenP
revitbadshah
in reply to: DarrenP
i tired to install revit architecture 2013 update 3...but didin't install giving me the error :1603
David_W_Koch
in reply to: revitbadshah
Do you have Revit Architecture (sold by itself) or Revit from the Building Design Suite? There are different Update files for these; make sure you have the right one for the product you have.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Rail Community
