I am having very frequent recoverable errors - havent seen any pattern but happens in veiws and mostly editing operations. I am filling in the error reports and there must be quite a collection now of mine. Anyone else having the same - update pack needed and when?
What kind of errors is it saying?
Are you on subscription? If so - open up a support ticket directly with Autodesk. If not contact your reseller to do this.
LD
After looking through the Error Reports that were submitted, it looks like the issue is related to a conflict between Revit and the graphics hardware or software on the machine.
I would make sure that your graphics card and driver are on the tested and supported list below. I would also try disabling Hardware Acceleration to see if the behavior changes.
http://usa.autodesk.com/adsk/servlet/syscert?id=18844534&siteID=123112
I also see you are saving to a drive "H:". Is this a local drive (or partition) or a networked location?
I am also having very frequent fatal errors, is it possible for you to have a look at the error reports that i have been submitting this afternoon.
we have just installed revit 2013 on new Dell Percision T1650 computes, with 16.0GB of ram. with a 64 bit system.
but since its been installed it has crashed more in 2 days that the whole time we had revit 2012 on old computers that weren't near as powerful.
Any ideas as to what is causing this problem.
Regards
Alice
