Revit Architecture 2013 decal settings won't stick
3 REPLIES 3
763 Views, 3 Replies
I can change the Decal Types settings in Revit Arch 2011 but not 2013.  I looks like I can change them but if I click OK and then open the Decal Types dialog box again to check the settings are back to default.  I'm trying to change the Finish and Luminance.  I tried it in several files with the same images (png and jpg) but it only works in 2011.
Tags (2)
3 REPLIES 3
Update
I filled out a trouble ticket with AutoDesk.  The Development team indicated that there needs to be a code fix, however they did not provide a time frame or a work around.  I will keep you posted.
85769EMS
I am also having the same problem with Revit 2013, but was not an issue with 2011.  I try to change the luminosity setting, but the settings don't save.  Any update on a possible fix?
Shawn
in reply to: 85769EMS
I am having the same issue with Revit 2014. Did any of you end up finding a fix?
