Revit Architecture 2012 edit boundary ribbon issue
25 REPLIES 25
Message 1 of 26
archytextural
7988 Views, 25 Replies
Below is the image of my ribbon after I begin the edit boundary command for a floor slab. For some reason the ability to finish or cancel the edit mode disappears and I'm unable to close out of the command without undoing everything I've done. Has anyone else expereienced this? and if so is there a solution? Thanks
Chris
25 REPLIES 25
Message 21 of 26
stella_chep
in reply to: archytextural
I had the same problem today and discovered that when I double-clicked the "Modify" tab (it may take more than 2 clicks), the "finish sketch" suddenly appeared!
Message 22 of 26
viddyaa
in reply to: stella_chep
Thanks! worked like a charm. 🙂
Message 23 of 26
bearsley
Message 24 of 26
dave
in reply to: opesch_
I just experienced this in Revit 14.
I found that by typing in a hot-key shortcut...DI for instance to put a linear dimension down...REVIT would bring the ribbon command back up associated with that command.  Then when escaping off that window, the ribbon for the boundary lines would reappear.
Message 25 of 26
ArthurDuguay
in reply to: Jenni722
Unfortunately not, I have to complete a plan made in 2012 and that's frustrating !! Have to play with the ribbon.
Message 26 of 26
bskaluba
Double click on modify/floor.......
