Revit Architecture
Member
mark
Message 11 of 24 (1,949 Views)
Re: Revit Architecture 2012-2013 edit boundary ribbon issue
10-10-2012 01:56 PM in reply to: regalith
We fixed it by starting a session of Revit double clicking the file in it's folder vs. opening the file from within Revit.
We do a bit of programming here with Addins and we think the addin has caused the issue. The addin won't load if you start Revit by doublle clicking the filename.
Mark.
Active Member
edwin
Message 12 of 24 (1,933 Views)
10-11-2012 10:49 AM in reply to: mark
One of our clients found that rolling back to an older .NET installation fixed the issue  which was happening in 2012 and 2013.
New Member
gj6172
Message 13 of 24 (1,846 Views)
Re: Revit Architecture 2012 edit boundary ribbon issue
11-13-2012 01:26 PM in reply to: archytextural
Opening the Revit file with a dobbleclick does the trick for me... Strange! Maybe someone from Autodesk would like to comment the subject?
New Member
Jesuite
Message 14 of 24 (1,705 Views)
02-01-2013 01:13 AM in reply to: edwin
I came through the same problem after installing the Microsoft .NET Framework 4.5 with Visual Studio 2012. After removing it and reinstaling the previous version of the .NET framework (Version 4), everything went fine.
Simon Moreau
www.bim42.com
Member
mark
Message 15 of 24 (1,580 Views)
03-18-2013 02:15 PM in reply to: mark
There is finally a fix for the issue.
Hotfix - Autodesk Revit 2012 - Ribbon behavior due to .Net 4.5 installation
Mark.
Active Contributor
MaddCatter
Message 16 of 24 (1,240 Views)
07-23-2013 11:13 AM in reply to: mark
Does the hot fix work on 2013 too ?
Active Contributor
MaddCatter
Message 17 of 24 (1,235 Views)
07-23-2013 11:21 AM in reply to: MaddCatter
The Hot Fix does not work in 2013.
Member
mark
Message 18 of 24 (1,229 Views)
07-23-2013 11:33 AM in reply to: MaddCatter
We seemed to have solved it in Revit Structure 2013 by installing Update Release 3 found here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21890545&linkID=9280927
Not sure if there is a similar update for Architecture
Mark.
Active Contributor
MaddCatter
Message 19 of 24 (1,219 Views)
07-23-2013 12:15 PM in reply to: mark
Excellent !!
That worked.
I had one issue on one of our computers that we had the Arch Revit loaded.  Had to go get a different SP for the Arch Revit Only.
Once I got the Service Packs ran, all three were working correctly.
Thanks for the fix !
:smileyvery-happy:
Active Contributor
scritchoune
Message 20 of 24 (1,037 Views)
10-10-2013 05:53 AM in reply to: mark
I still have got the problem While I'm working on Revit 2014 SP1.... Rolling between Ribbon sizes doesn't recover the buttons (tough I remember it worked on previous releases)
neither " press ALT + M + FM this will essentially press the green check to finish your command. Or use ALT + M + XM to Cancel."
nor setting new shortcuts nor refreshing all UI panels recover the buttons....
I don't know what else I can do to finish/cancel my floor !?!
[edit] Freeeeedoooom !
Clicking the little save file button and then cancel has finally cancel the whole editing mode without having saved the file locally....
So it's the only working solution left with 2014 sp1 !
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
