Revit Arch 2013 print with no hatch patterns.
7 REPLIES 7
Message 1 of 8
3189 Views, 7 Replies
I currenly made the change to Revit Architecture 2013 and enjoy the new features (not many, but a few). I do alot of work for school where i plot camera views in hidden line and hand render from there... sometimes its a nicer look. anyway for some reason i can not print the hatch patterns that appear on my screen. I have tried printing in raster rather than vector and that did not work. I need the hatch patterns to print, if i cant i will go back to 2012 but i cant transfer the model back because Revit does not have a save as 20** option. Any help would be greatly appreciated.
7 REPLIES 7
Message 2 of 8
Sometimes if the hatch pattern is too small in the view
it won't print. Just like sometimes you can't see it unless
you zoom in.
Message 3 of 8
parveen.revit
can you go into the properties of hatch patter/filled region and check the properties of line spacings. also see attached image.
Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
Message 4 of 8
in reply to: parveen.revit
I appreciate the information, but the hatch pattern that is not printing is the wood shake pattern. It is not a simple crosshatch, but a .pat file.
Message 5 of 8
also just found out that the simple 6" horizontal pattern is not showing up as well.
Message 6 of 8
AndrewJohnson3370
Got the same issues, model hatches will not print (or preview) when Print Range is set as Current Window or Selected Views/Sheets. But it works if Visible portion of current window is selected. I have brought this up with my supplier & am awaiting a result.
Andrew
Message 7 of 8
chris
I have this same problem.  is this a known issue with 2013?  very frustrating...
Message 8 of 8
andrew
in reply to: chris
Same issue directly after upgrade to 2013.
-Hatch patterns print in Hidden Line mode but do not in Consistent Colors.
-Same issues PDF or hard copy.
Great part is I can't downgrade the project back to when things were working properly... THANKS!
